Fresh Water Drain Valve |
Post Reply | Page 12> |
Topic: Fresh Water Drain Valve Posted: 24 Feb 2018 at 5:19pm |
I put a valve drain on mine, no more cap. It extends down about 2 inches, works fine.
Posted: 24 Feb 2018 at 4:28pm |
Then they could be damaged by thrown road debris? |
01tundra
Newbie Joined: 12 Dec 2017 Online Status: Offline Posts: 8 |
Posted: 24 Feb 2018 at 1:31pm |
Didn't realize the pods were different. Couldn't you add a threaded brass elbow in place of the plug and convert to barb fitting, then screw a valve bracket to the frame like ours has?
Leo B
Posted: 24 Feb 2018 at 1:29pm |
We do the same as Wepod, open up the lower point drains and ho water tank then drive the back roads for a few minutes. Drains it all!
Posted: 24 Feb 2018 at 12:23pm |
One can push up on the bottom of the tank and get more to drain. However, that is far from an ideal way to get the water out. If the bottom of the tank were supported so that it did not sag, then I don't think it would be so much of an issue.
Wepod
Groupie Joined: 07 Feb 2017 Online Status: Offline Posts: 82 |
Posted: 24 Feb 2018 at 12:20pm |
I found the only way to get all the water out of the tank is to leave the cap off and drive about 10mi.
ron_whitt
Senior Member Joined: 08 Sep 2011 Location: Chesterville On Online Status: Offline Posts: 261 |
Posted: 24 Feb 2018 at 12:16pm |
What StephenH just said...
Ron & Shirley
2020 Tacoma 2012 177 rpod |
Posted: 24 Feb 2018 at 12:01pm |
It isn't just you. |
mjlrpod
Posted: 24 Feb 2018 at 11:59am |
Pods don't have this type drain. Ours is just a plug. My only wish about the drain plug is, I wish it was at the lowest point of the tank. One tends to think a tank drain will drain ALL of the water out of the tank. Maybe its me.
Leo B
Posted: 24 Feb 2018 at 8:11am |
Nice job!!
