A poll on WDH w/sway control |
Post Reply | Page <1 456 |
Topic: A poll on WDH w/sway control Posted: 19 Jul 2020 at 4:01pm |
Is that 270 tongue weight an actual measured value for a loaded trailer? Seems very low.. FR specs say an unloaded dry 178 is 295 on the hitch and 2893 total. That's with no battery, water in the water heater, or any of the tanks...If it really is that low then you'll also want your total trailer weight not to exceed 2700 lbs to avoid sway. If you are Ok you will be very close, so check all your actual loaded weights against your Jeep specs (trailer, tongue, combined gross vehicle weight, and axle weights). When you run through the scales disconnect or de-tension the weight distribution hitch, it will throw off your weight measurements. Here's a nice calculator to load all your data into and see where you are. . |
Blue Ridge
Newbie Joined: 25 Sep 2019 Location: NOVA Online Status: Offline Posts: 7 |
Posted: 20 Jul 2020 at 7:47am |
I use a fastway e2 600/6000 square bar, no complaints so far.
Sailor Pod
Newbie Joined: 15 Nov 2018 Location: Michigan Online Status: Offline Posts: 8 |
Posted: 08 Sep 2020 at 7:28pm |
We use a husky centerline WD hitch and sway bars on our R-Pod 190. Works great. 600lbs. We tow with our diesel jeep grand cherokee, which also tows the pod very well. We just put on 5000 miles going to Seattle and back. Trip was outstanding.
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2624 |
Posted: 09 Sep 2020 at 1:06pm |
We recently got a reminder of why we use a WDH.
We were evacuated from our home when one of the big fires started in California. We had everything packed, and part of our belongings we wanted to take with us was our RP-179. Seeing that we were getting underway at 3AM, and we have an F-150, which can pull the 179 with no control issues whatever, I decided I would skip the WDH setup. As we proceeded down the highway, I noticed two things. First, the headlights were just a bit too high. Just high enough that the low beams would shine right into the windshield of anyone coming the other way. Not a good thing. The second thing I noticed was that all the bumps and dips were exaggerated. After we got to our first stop (what we affectionately referred to as "Chateau de CVS"), we got a few hours of rest, and before we left, I hooked up the WDH bars. The rest of our escape to safety was uneventful. |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6283 |
Posted: 09 Sep 2020 at 2:31pm |
Yes, it is amazing what a difference a well-set-up WDH can make, especially if it also has sway control, whether integrated or add-on.
