Wind deflector |
henryv
Senior Member Joined: 09 Feb 2017 Online Status: Offline Posts: 259 |
Topic: Wind deflector Posted: 12 Mar 2018 at 6:37pm |
Somebody recommended an aeroshield or aerodynamic wind deflector. At first I thought they were talking about one for the R-pod. But it looks like they are for the tow vehicle. Anybody know?
GlueGuy
Posted: 13 Mar 2018 at 11:27am |
There are two kinds of air-flow control typically used. Air deflectors usually go on the tow vehicle and attempt to smooth the flow of air in the void between the back of the tow vehicle and the front of the trailer. Those are mounted on the tow vehicle.
The second kind of air-flow control are vortex generators and/or spoilers. The "big butt" versions of the R-pod have a spoiler that disrupts the airflow off the back of the R-pod to reduce the vacuum that exists there. I'm not sure how effective that is, but there are vortex generators that you can install along the rear edge of the R-pod to try to fill in that same vacuum. At least one of our forum members has installed the vortex generators: http://www.rpod-owners.com/forum_posts.asp?TID=3916 |
TheBum
Posted: 13 Mar 2018 at 11:28am |
You can get air deflectors for the TV, but the highest speed rating I've seen on one is 60 mph. If you sometimes drive 70 like I do, it might not handle the strain.
Alan
Posted: 13 Mar 2018 at 9:04pm |
I use the AeroPlus by PurpleLine USA. If you don't have an existing roof rack, the AeroShield by Icon is the better choice. Limiting tow speed to 60 mph is not a problem. We arrive much more relaxed and with more money since we don't use as much gasoline as would be used at higher speeds. In addition, the legal towing speed in a number of states is 55 or 60 mph. It is legal to to faster in some states, but see the above for why to tow slower. The journey is part of the adventure.
