worthless refrigerator on propane |
Post Reply | Page <1234> |
cgarb
Groupie Joined: 27 Mar 2011 Location: California Online Status: Offline Posts: 95 |
Topic: worthless refrigerator on propane Posted: 27 Jul 2018 at 7:54pm |
Now we are having trouble keeping our refrig in the safe temp range when plugged in. Should it get up to 50 degrees when it is on full power and empty? It got up to the mid 90s outside, but is down a bit and the pod is in the shade. My husband checked and the vents are all clean and the pod is level.
Carol
177 HRE rpod 2014 Honda Pilot |
Posted: 23 Jul 2018 at 8:04am |
Did you move it and not level it? It needs to be at least close to level to work properly. You might also try tapping on the plumbing behind the refrigerator to see if something settled out and might be blocking the flow partially. Tapping on it might get things flowing well again. While you are at it, take a compressor and blow any dust out of the fins.
cgarb
Posted: 23 Jul 2018 at 5:48am |
We had a new refrig put in our 2011 177 about a year ago. It worked really well for a couple of trips then has been sitting for months. We used it as an extra refrig on holidays and it was fine. Now it won't work when plugged into the house. The temp only got down into the 50's yesterday after being plugged in for 24 hrs. And of course we have it up for sale. What timing! Just got the water system working well! Any suggestions?
Carol
Posted: 15 Jul 2018 at 10:18pm |
Thanks.
Posted: 15 Jul 2018 at 10:08pm |
The 8501 and 8505 are 22.36 inches deep The 8551 and 8555 are 24.52 inches deep I misspoke earlier. All four models are 32 inches tall. The differences are in the depth. I'm now thinking the lack of indicia is intentional. This allows them to switch around the different refrigerators with little or no consequence. How would we measure the depth without removing the fridge?
cgarb
Posted: 15 Jul 2018 at 9:54pm |
I wonder if it is the earlier model like we had to replace. The front of the owners manual lists the models it covers in 3 groups: RM 8501 - RM 8505, RM 8551-RM 8555 and RML 8551-RML 8555.
Maybe if you went to the Dometic site if you could compare them.
Carol
Posted: 15 Jul 2018 at 9:37pm |
I wonder what the difference is between the 8501 which is the model in mine and the 8551.
cgarb
Posted: 15 Jul 2018 at 9:31pm |
Hm. My post didn't seem to go through. I did find the info behind the crisper drawer. It was too hard for me to read so I took a picture of it. It is a Dometic, Type C40/110, Model number: RM 8551. Hope that helps. Good luck!
Carol
Posted: 15 Jul 2018 at 8:53pm |
I thought they surely must have a sticker or something "somewhere"... However, I looked all around the front outside, inside, in the freezer compartment, under the freezer compartment, in the crisper. Nothing nada. Then I popped off both of the vents on back, and checked all around in there too. Nothing. There is a little label near the bottom with some safety information, but no model numbers. Then I thought, how many 3.7 cu-ft 3-way refrigerators can they make? I found one. Here it is:
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 15 Jul 2018 at 7:17pm |
Stephenh - I'll look up the model info on mine tomorrow (have guests coming in a few minutes). Its a year old, works beautifully. No trouble getting very cold fridge temps w/propane even on #4 setting.
