Bed Shelf |
Post Reply | Page 123> |
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Topic: Bed Shelf Posted: 23 Jun 2018 at 10:36am |
That sounds like nice stuff. I used hemlock, key is to get the shelf as light as possible. I used lauan mahogany underlay plywood (3/16") with 1/2" board for edges/sides. Even full-width shelf doesn't weigh much.
Billy Bob
Senior Member Joined: 11 Jun 2018 Location: Boulder City, N Online Status: Offline Posts: 103 |
Posted: 23 Jun 2018 at 9:06am |
I've got some cypress flooring ill use...run it through a planer glue together and install......bed, dinette, bath, and outside.
2019 RPOD 190
2017 Chev Colorado 4 X 4 Yellow Lab and English Springer Spaniel |
Retired Coastie
Newbie Joined: 14 May 2018 Location: Salem, Ohio Online Status: Offline Posts: 6 |
Posted: 21 Jun 2018 at 6:56pm |
Measured and made my own. One out of walnut the other cherry. Watched the outside of the camper to locate the studs to attach the shelves. Made a cherry one for the bathroom too.
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 27 Apr 2018 at 8:08pm |
I was in my Lowes today too and they didn't have the wooden shelf in stock. There answer as always at this store....you can order it, ugh! After looking at all the shelving material with the wife were more incline to go with the metal one now as you have. They have the advantage that you mention plus lighter weight. A win, win, I'd say. |
Posted: 27 Apr 2018 at 4:17pm |
DavMar,
Looked at the wood shelf today at Lowes - 75 bucks, I also wanted the over bed light to be somewhat functional. I felt the wire shelf provided more light through to sleeping area. |
Ben Herman
Posted: 27 Apr 2018 at 3:53pm |
I just removed my valances so don't have a photo of them installed - but basically they use metal angle brackets (the same ones that FR uses as drawer pullout limiters - if you look in the drawers you'll see what I mean). One side of the bracket is attached to the wall with 2 - 5/8" screws, and the other side with 2 - 5/8" screws to the inside of the valance. Not terribly sturdy. Hard to get to the screws to remove the valances, had to get on my back on the bed with a drill with a long Phillips extension.
DavMar
Posted: 27 Apr 2018 at 9:27am |
Thanks everyone for your inputs on how you did this shelving mod, just keep them rolling in! At $75 for a wooden shelf it makes pause and think maybe wire might be the way to go, don't know? I'll have to take a hard look at the valances and how they attach if anyone has a photo of that they can post it would be appreciated. Again thanks for all the great suggestions!
Posted: 27 Apr 2018 at 9:23am |
The interior panel is not fiberglass, but is thin lauan plywood with a wallpaper cover. If you use an expanding anchor, (make sure it is less than 1" in length or you will experience outer wall puncture (ask me how I know ). Fortunately, when the R-Pod went to the factory for repair, they replaced that side so no more puncture evidence.
Ghosthawk
Senior Member Joined: 01 Apr 2018 Location: Fargo ND Online Status: Offline Posts: 128 |
Posted: 27 Apr 2018 at 7:07am |
Thought about attaching an L shaped piece of wood the length of the shelf with Command Strips.
Unsure how much load it would handle. I have expandable shower curtain rods in my Amazon Basket, should take more load properly installed and should do no damage. But it is a more costly option. If I could be sure I would hit the aluminum frame I would drill it and put in an anchor. But not sure I want to trust my wifes packing them full to just a few screws into fiberglass panel. |
Posted: 26 Apr 2018 at 9:55pm |
The shelf itself is not that heavy. Metal shelving would be heavier I think. The wood used for them is very light but the shelf seems to be quite sturdy. Mine rests on the valences, but the command strips I have do support some of the weight as well. I don't load it down with heavy items. Other than my CPAP machine, the baskets we have on it hold my clothing as my wife uses the wardrobe drawers for hers. A lot of items either go in the wardrobe on th ecloset rod or on a separate rod that Iuse in the TV to carry any hanging items that won't fit in the wardrobe.
