Spare Tire Mount on Front [Critique] |
Post Reply | Page 12> |
Author | ||
Topic: Spare Tire Mount on Front [Critique] Posted: 26 Apr 2018 at 9:50pm |
HikerSteve
Newbie Joined: 21 Jan 2017 Online Status: Offline Posts: 15 |
Posted: 26 Apr 2018 at 7:20pm | |
Yeah, looking at the pictures it might not be too bad. Right now I can scrape a rear jack if I don't hit the driveway right. Being centered like that might not be bad. What do you want for yours? I might give it a try.
HikerSteve
Posted: 26 Apr 2018 at 7:17pm | |
Anyone have one of these? I might just get it and put the tire on the back again.
https://goo.gl/UzokqN
David and Danette
podders Helping podders - pHp Joined: 24 Nov 2009 Online Status: Offline Posts: 1215 |
Posted: 26 Apr 2018 at 5:23am | |
When we had our r-pod 171, I bought from Northern Tool a spare tire carrier bracket that I bolted to the front frame and I don't remember it ever being a problem with sharp turns. I did it to move more weight forward for better towing with less sway.
voisj
Senior Member Joined: 19 Jul 2016 Location: San Luis Obispo Online Status: Offline Posts: 471 |
Posted: 26 Apr 2018 at 12:01am | |
HikerSteve,
Here's my take on a front tire mount (the bike thing) before I got the BAL undermount unit, Which took some pounds off the front and put it down low just in front of the axle, (on a 180), And allowed for other tongue mods. I think you will find the undermount does not really impact ground clearance so much as you don't put it all the way out back, should sit forward a few feet from the rear on a 179. This is really the best way to go to keep tongue weight down. IMHO. Taking the tire off the back and moving it up front means less weight in back and more on the tongue, Think teeter totter.
I played with the same mount you have and it messed with the ability to back up tight into my awkward driveway, so I did this.
I used the tire carrier, notched the front angle iron that holds the batteries and welded it all together. Had to move the propane tank a few inches forward , and the tire sat nice and tight on the frame. I even added a second tank and it worked well. I just noticed your battery's sit higher and further forward than mine and would require a bit more work to put fit it all in. Here's the undermount unit, 14" in front of the axle on the 180. And now the front looks like this. I am thinking of re-doing the whole thing now to reduce weight up front, with all my mods inside and out, I'm now pushing 600 lbs up front on the ball, with the empty front fresh tank. (2 propane tanks, elec jack, battery box & 2 GC-6volts, Plus the inside twin bed stuff and drawers. Or maybe just a custom lift and move the axle forward til it gets under 500 lbs with the fresh tank full. cheers, John |
CharlieM
Posted: 25 Apr 2018 at 10:20pm | |
My original write up and pictures got lost with the new forum. @fwunder copied my original mod and posted new pictures http://www.rpod-owners.com/forum_posts.asp?TID=9619&KW=swagman&PID=90640&title=mount-bike-rack-in-place-of-spare#90640. Scroll to the top to see his installation. I still have pictures but posting them to this forum is a PITA. Send me a PM with your email and I'll send them to you. |
Posted: 25 Apr 2018 at 9:33pm | |
I do have a BAL carrier that I am no longer using since I made a ladder carrier and sewer hose carrier that take up that space. I would prefer to find a new home for it rather than let it sit and rust or throw it in the trash.
Since the BAL sits closer to the axle than the rear jacks, it is less likely to scrape. It sits as high as the steps since the tire sits recessed between the frame rails and not below them. I don't think you would have any problems with one. |
HikerSteve
Posted: 25 Apr 2018 at 6:56pm | |
I did and I really like it. Currently I scrape getting the camper in the driveway if I don't hit the angle just right so my fear with the BAL is clearance getting in and out of my driveway.
HikerSteve
Posted: 25 Apr 2018 at 6:53pm | |
Do you have pictures or a write up of your current set up? Essentially that is what prompted the move is for me to haul bikes off the back.
texman
Senior Member Joined: 24 Jul 2014 Location: TeXas Online Status: Offline Posts: 446 |
Posted: 25 Apr 2018 at 10:00am | |
did you consider the BAL tire carrier that mounts underneath the trailer in the rear?
