DavMar
Topic: "Redneck" Yeti Cooler Posted: 05 May 2018 at 8:36pm |
Thought I’d share this mod I did on an old Coleman cooler
I have. Like many of you we carry an extra cooler with us when were camping in
order to keep drinks cold and such to free up refrigerator space. After buying
a bag on ice once a day or more in the summer while out camping I said this is
crazy but even crazier is spending $400 plus to buy a Yeti cooler or one of
their competitors just so we can have ice for more then a day. After some research,
seeing some youtube video’s, I said I can do this do this and improve the cooling
function for cheap.
I took our ratty fade burgundy cooler we had and first
lined the box with foam board on sides, top, and bottom. Gluing the foam board
in with silicon calk and sealing the seams with the same calk to make it water
proof and then using metal foil duct tape to seal the top and lid area. Well just
this simple modification extended a bag of ice from one day to three! Now I
decided to see if I can get one or maybe two more days cooling by using
injectable foam insulation in the lid of the cooler because they put zero
insulation there. So out with my 1” hole saw and I drilled six holes in the lid
so I can easily spray the foam insulation inside and fill the void. After it
set I cut always the excess dried insulation and then filled the holes with
some auto body filler I had. Repainted the cooler to match the Pod and our
truck and think it turned out pretty good. Now the question is will the extra
work filling the lid with insulation foam extend the cooling capacity? Only
time will tell but I’m already pleased with the money saved on ice.
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
MelissaJoy
Posted: 06 Apr 2021 at 8:39am |
This is great! It is insane to spend $400 for a cooler. Nice work.
Pod People
Posted: 06 Apr 2021 at 10:03am |
We modified our Engel cooler by wrapping it with 3 layers of reflectix on the outside. We have had solid block ice or frozen gallon jugs last as long as 8 days. here is the lower section for the cooler-it has cutouts for the handles and latches, there is a velcro closure on the left side
The top is separate and easily pulls off for access
together Vann
Vann & Laura 2015 RPod 179
DavMar
Posted: 06 Apr 2021 at 10:08am |
Thanks for the compliment. We've used this cooler for a couple years now. Yes, it doesn't match the performance of a Yeti cooler but its also be made for a fraction of the cost. A bag of ice will keep things cool for more then a day so that's all we need to store our "adult" beverages
wonder dog.
2017 Rpod 180
Lexington, NC
DavMar
Posted: 06 Apr 2021 at 10:17am |
Not a bad idea! I used Reflectix insulation to wrap a electric powered BBQ smoker with great results. Before I did that I had to crank it full blast to get it up to 250 degrees on a cold day. Now it makes that temperature in low medium range a big improvement! So I can see how wrapping my "redneck Yetti cooler" would help.
wonder dog.
2017 Rpod 180
Lexington, NC
Posted: 06 Apr 2021 at 10:19am |
That is great, thanks for sharing! Now I have more 'stuff' to do in my spare time. Have an older Coleman cooler (green 1976) that is going to get an upgrade!
Pete Brayton
Posted: 06 Apr 2021 at 11:03am |
Amateur astronomers use Reflectix to slow the temperature change issues with our telescopes. I also have some leftover pieces that fit my 196 windows.
2021 Rpod 196
2013 Ford 150 V8
campman
Posted: 06 Apr 2021 at 11:24am |
I am definitely liking and following this thread. Some great idea's for upgrading an old cooler or 2 we have at our camp. They are useless for keeping anything cold for any length of time, and we need a cooler (for fridge overflow) in the back of the truck for our road trip this summer (once we get our ordered 192). Adding left over reflectix from when we built our sauna several years ago seems like a great way to use up some of the things I can't just throw away! Spare Reflectix for the windows in the trailer is a great idea as well, both for heat and cold management. Keep the great ideas coming!
Andy and Laurie
'21 RP192
Red-Green
DavMar
Posted: 06 Apr 2021 at 11:45am |
Hmmm...now this thread is making the old light on the thinking cap go off! I have some left over Reflectix, from my BBQ smoker project (which by the way now looks like a rocket ship that's missing nose cone) which I can use to glue to the inside on the foam board of my "redneck" Yeti cooler for even more efficacy. Since the stuff is only plastic bubble rap covered with reflective foil on both sides ..... hmmm!
wonder dog.
2017 Rpod 180
Lexington, NC
MelissaJoy
Posted: 06 Apr 2021 at 11:50am |
When you put this on your windows, did you get a lot of condensation between the window and the Reflectix overnight when it was cooler outside? @campman
