  New Posts New Posts RSS Feed: hollow space between toilet wall and control wall
Topic Closedhollow space between toilet wall and control wall - Event Date: 24 May 2018
retiree04 View Drop Down
Direct Link To This Post Calendar Event: hollow space between toilet wall and control wall
    Posted: 24 May 2018 at 8:17am
For storage purpose, can I cut out a lower portion of the wall to the left of the entry door to insert a storage cabinet between the two walls, without running into the wiring for the control panels mounted higher on the wall?
retiree04
Jeff
Direct Link To This Post Posted: 24 May 2018 at 9:29am
Welcome back.
Without knowing which model, it is hard to say. It is possible that there is not only wiring in that space, but also a vent stack. Before cutting, look on your roof above the space in question and make sure there is no tank vent above it. Wires are fairly easy to move aside. Vent stacks aren't.
TheBum View Drop Down
Direct Link To This Post Posted: 24 May 2018 at 11:48am
I have the same concern about installing a recessed toilet paper holder. I've thought about getting one of those wifi optical probes to see what's inside the wall before I start cutting, but it still requires at least one hole in the wall. I could detach the shower sink I suppose and feed it in behind that.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Direct Link To This Post Posted: 24 May 2018 at 12:32pm
If you take out the sink, a simple flashlight and mirror combination could work for viewing. You don't necessarily have to spend the money on a fancy optical probe.
Direct Link To This Post Posted: 24 May 2018 at 1:25pm
Thanks!  My 177 r pod does have the overhead vent pipe that appears to be over the hollow space so I will not cut into the wall for additional storage.
Jeff
Direct Link To This Post Posted: 24 May 2018 at 1:27pm
Thanks! the vent pipe does appear to be over the hollow space.
Jeff
Direct Link To This Post Posted: 24 May 2018 at 9:31pm
Good thing you checked before you cut.
Direct Link To This Post Posted: 24 May 2018 at 9:59pm
I have a 172, I put in a recessed cabinet above the toilet, the wall behind is a 2 x 4 wall. If the wall has a stack in it, it's  normally a 2 x 4
Direct Link To This Post Posted: 25 May 2018 at 10:48am
Yeah, it really would have stunk if you didn't find that out beforehand...literally.
Alan
Three cats
Direct Link To This Post Posted: 25 May 2018 at 1:13pm
Mine is sunk into the wall by 3", the cut out served for the back of the cabinet.
