Axle grease - Event Date: 26 May 2018 - 30 May 2018 |
Calendar Event: Axle grease Posted: 29 May 2018 at 3:54pm |
I think tires are something that needs attention and inspection by various locales. I have had exposed tires in AZ and same in TN and they are effected different by sun and weather. I personally cover my tires in storage to keep them out of the elements. Four years doesn't seem outlandish to me, but you can expose tires for two years and they suffer.
Posted: 29 May 2018 at 3:43pm |
olguy
Newbie Joined: 15 May 2017 Location: Houston, TX Online Status: Offline Posts: 7 |
Posted: 29 May 2018 at 1:48pm |
Many thanks. Been using the "touch" method, that works fine also.
Cliff |
olguy
Posted: 29 May 2018 at 1:43pm |
Many thanks. Now on to decision as to Carlisle tires. Lots of tread, no cracking, however they are (4) years old and we are heading out soon on 4000 mile vacation.
Cliff |
TheBum
Posted: 29 May 2018 at 10:57am |
I use Lucas Red-n-Tacky on our 179's bearings. It meets the recommendations of our Lippert axle. It's readily available almost everywhere here in north Texas.
Alan
Posted: 26 May 2018 at 3:30pm |
Dexter recommends lithium-based grease. Their recommended brands is in their how to grease document (below). Some people use an infra red sensor to measure the temperature of their hubs. I generally just put my hand on the hub when we're stopping. It's OK for them to be a little warm, but they should not hot. If I think the hub is too hot to hold my hand on, then something is amiss. |
olguy
Posted: 26 May 2018 at 2:13pm |
What is the recommended grease for 178 hubs. Tip...I went to Farmers supply and purchased an infer red (SP?) temp sensor. shoot the hubs every couple hundred miles. Running about 35 degrees above ambient.
Cliff Olguy |
