Annie
Online Status: Online
Topic: Smell from shower drain Posted: 05 Jun 2018 at 10:41am |
no smell from toilet but shower drain smells. Is it grey water tank or black tank? We never use shower, only once or twice last year. The smell is like rotten eggs. Help
Posted: 05 Jun 2018 at 10:48am |
The sinks and shower drain into the gray water tank. If you've never used the shower, it's likely that the trap is dry, and sewer gas from the gray water tank is wafting up into the pod. The simple solution is to pour a few cups of water into the shower drain to re-fill the trap. That should block any of the smell.
Annie
Posted: 05 Jun 2018 at 2:03pm |
Thank you, I will definitely try that.
Posted: 05 Jun 2018 at 3:35pm |
Also you might consider throwing a little of that blue chemical stuff into the gray water tank too. It gets pretty icky when the water, filled with plenty of delicious food for microbes, just sits there in perfect bacteria growing temperature.
TheBum
Posted: 06 Jun 2018 at 10:37am |
We've found that a large bottle of lemon juice will freshen things up too. Microbes don't generally like citric acid.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Live2Camp
Posted: 06 Jun 2018 at 1:40pm |
Also you might consider throwing a little of that blue chemical stuff into the gray water tank too. It gets pretty icky when the water, filled with plenty of delicious food for microbes, just sits there in perfect bacteria growing temperature. |
This is a good tip. It's also why I wash dishes in a dishpan instead of directly in the sink. I am seriously compulsively serious about not letting food bits or oils (or fruit juice or coffee or tea or pretty much anything but plain ol' agua) go down the drain. The lemon juice suggestion is a good one too, and I'll make a point to keep it in our Pod.
His:Ford F150 double cab 4WD; Hers/mine:Tacoma V6 double cab 4WD
Still love rugged, diggin' comfy too
Posted: 06 Jun 2018 at 3:44pm |
I mix the "blue stuff" in a bucket and pour it down the kitchen sink. I do it before starting trip, that way it sloshes around grey tank.
Posted: 07 Jun 2018 at 8:28pm |
Live2, what do you do with the water that has all the stuff you don't want to go down the drain? How do you get the gunk out before disposing of the water?
Live2Camp
Posted: 08 Jun 2018 at 10:51am |
I’m finding that the habits I’ve developed for food handling
and dishwashing in decades of camping and backpacking in bear country are serving
me well with our RPod. That and living with a septic tank at our house (although it's a lot less "sensitive"). I wipe
food off dishes and utensils before putting them in the dish pan. This makes more
efficient use of soap and water too of
course. I also readily use paper plates when it’s obvious that I’ll be using a
lot of paper (to wipe dishes) and might as well save the water, soap and energy to
both heat the water and pump it. In campgrounds there is usually a place to
dump dish water. With dispersed camping, in most of our areas it’s completely
acceptable both regulations-wise and environmentally to dump dishwater on the
ground. I do this well away from where we’re sleeping and also using biodegradable
(in soil) soap; and well away from any water sources. I never dump food scraps
or greasy/oily anything, anywhere but proper disposal (which does not include
the RPod’s black tank). And never on the ground even in really remote
locations. To me that is both littering and feeding wildlife, neither of which
I want to do. I’ve even been known to skim dishwater with a cotton cloth or
paper tower in the “just to be really sure” department. As a side note, I would also never empty our gray water tank on the ground on public lands; besides being against most regs it's completely unnecessary. There's a distinction between dumping a small amount of dishwashing water - as one does when backpacking for example - and an entire tank. In campgrounds it’s
obviously rude at best to dump water on the ground so if there’s no designated
place for that, I dump it in the RPod toilet so it goes to the black water
tank. Even though I’m
serious about the topic, it’s not a burden or in any way difficult to do any of
this and I do it all very light-heartedly as part of our camping experience. Also - many people tout dumping dishwater and/or food scraps in
their campfire pit. I recommend against it since it attracts wildlife into your
campsite (which will be someone else's campsite after "you" leave). Hope this helps!
