What is this propane part called |
MadCity
Newbie Joined: 18 Aug 2017 Location: Madison, WI Online Status: Offline Posts: 14 |
Topic: What is this propane part called Posted: 10 Jun 2018 at 2:25pm |
What is this piece called? The "aluminum block" with 2 bolts attaching it to the trailer and two hoses and a quick-connect attached to it? This one is in the front of the trailer. I have one in the back left with an extra connection that I plan to add another hose and extend it to the opposite side of the trailer. From there I need the additional "block" (whatever it is called) to attach to the trailer so I can add the extension hose (from the back left "block") and another quick-connect. I've tried searching the net in vain. It's hard to search when you don't know what to call the thing. Thanks! |
2018 R-Pod 176T
2008 Honda Pilot AWD |
Senior Member Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3224 |
Posted: 10 Jun 2018 at 2:47pm |
My pod is too old and doesn't have this but from your pic it appears to be a quick attachment for a gas/propane grill. The threaded hose that is attached to the aluminum block, trace that line back to the source; probably ends at the propane tank.
MadCity
Posted: 10 Jun 2018 at 2:53pm |
Hi Jato, Thank you for the quick response. I tried to explain the piece I was referring to, but it's difficult in words. The piece is not the quick-connect, it's the "blocky" part that everything attaches to (including the quick-connect and hoses). It's the "aluminum block" piece that I am trying to identify. It has 2 bolts holding it on to the RV frame and 3 openings. One the quick-connect goes into, and the other 2 the hoses attach to. I hope this helps to further clarify. It must have a special name, because when I search for propane parts I can't find it.
2018 R-Pod 176T
mjlrpod
Posted: 10 Jun 2018 at 3:11pm |
Normally that would be called a manifold.
Posted: 10 Jun 2018 at 7:31pm |
Sorry Madcity. I didn't read your question correctly. However mjlrpod has correctly identified the part. |
wthoms2000
Groupie Joined: 06 May 2017 Location: Costa Mesa, CA Online Status: Offline Posts: 44 |
Posted: 13 Jun 2018 at 12:12am |
This is known as a tee in plumbing, along with street elbows and plugs and caps. Was not able to find this mountable alum tee, but found a brass tee:
https://www.campingworld.com/propane-adapter-tee Good luck! |
Porta Poddy
Wil and Luz, Orange County, CA 2017.5 179 HRE 2021 Ranger XLT FX4 REDARC Brake Controller |
