Lost battery power inside my 171 |
Post Reply | Page <12 |
JoeSaint
Groupie Joined: 06 May 2018 Location: WI Online Status: Offline Posts: 40 |
Topic: Lost battery power inside my 171 Posted: 24 Jun 2018 at 6:47pm |
To eliminate the possibility of a bad disconnect switch, I took a car jumper cable and went across the two terminals and still nothing. The two fuses I checked were the 40 amp polarity fuse and the 30 amp main 12v fuse, both are good
Posted: 24 Jun 2018 at 7:34pm |
Have you checked your connections? They can look good but not be. At least try to wiggle each end of every cable. (They shouldn't wiggle.) The wiggle test isn't conclusive. TT
FJ Cruiser |
Posted: 24 Jun 2018 at 7:35pm |
My suggestion was to remove the switch from the circuit, not jumper it. Connect the RV's red positive cable to the battery's positive terminal and the white negative cable to the battery's negative terminal directly. Do you have a multimeter? If not, head down to your local hardware place (Lowe's, Home Depot, Ace, Harbor Freight) and pick up an inexpensive multimeter. HF would probably be the least expensive place to get a cheap one that will be adequate for this purpose. Take a DC voltage reading across the two battery terminals. If you have >12V, your battery is probably good. If <12V, it could be weak or dead. However, you say your jack works, so the battery is likely good. While you are at it, check to see that you have the red wire from the R-Pod connected to the positive + terminal and the white wire to the negative - terminal. It is okay to take a jumper from the negative terminal to your cut-off switch and then connect the trailer's white wire to the other terminal. This is the safest way as the rule of thumb is connect negative last, disconnect negative first. Set the meter for Ohms. Disconnect the switch. Take a reading across the terminals with the switch in the off position. The meter should give a reading of 1 . if there is no continuity (Cen-Tech Digital Multimeter used for reference set to 200K Ohms). Turn the switch to the On position. The reading should change to 00.0 Ohms. If it remains at 1, then the switch is bad. If the switch is good, then reconnect your jumper from the negative terminal and reconnect the trailer's white wire to the other terminal. Make sure no wires are shorting out against the frame. I don't know where your switch is mounted, but make sure nothing is shorting with it or its mounting either. How did you check the 40A fuses (should be two)? Did you do a visual check or use a meter? If visual, use the meter to check each fuse. It can appear to be good but in reality be blown. I've had that happen. If, while you were putting in your battery cut-off switch, you managed to reverse the polarity, even for a second, one or both of those are blown to protect your converter. The two are to the left of the larger stack of 12V fuses for the various appliances, lights, refrigerator, etc. If one is or both are bad, replace them with new 40A fuses. For the regular stack of fuses, on mine, if a fuse is blown and there is still power available, an LED light will show next to the blown fuse. If you remove one of the fuses on the main stack, say the one for the Bathroom or Porch light for example, do you see an LED light next to the socket? I just remembered that WFCO has a troubleshooting chart for their converters. You can find this flow chart for the WF-8900 here. The same chart is suitable for other WFCO models as well. That might be the better way to proceed with troubleshooting your power problem.
JoeSaint
Posted: 24 Jun 2018 at 7:54pm |
Hi StephenH, I have a meter and the batt is reading 12.5v. When I put the dis con switch in I only disconnected the neg wires. There is only one 40 amp fuse and it says its for reverse polarity protection. Then there is a 30 amp that says battery. I checked them with an ohm meter that sounds when there is a solid connection. At this point there are no led lights on either side, but not sure if there are any. The converter is wh-8734/8740 so I’ll check that link you sent also. I know it was all fine after the disc sw because I was in there playing with my new storage stuff. Thx
Posted: 24 Jun 2018 at 8:29pm |
Good luck! I hope you get the problem diagnosed so you can fix it.
JoeSaint
Posted: 25 Jun 2018 at 8:51pm |
StephenH, here’s an update..... I called the dealer and he said there was one more fuse behind the converter under the seat. It was a 10 amp, but not blown. So I thought I’d check each fuse on the front of the converter. I had already checked the 40 amp polarity and the 30 amp battery and they were good. BUT when I got to the next one which was a 15 amp, it was bad. And when I pulled it out a red LED cane on next to it. I swapped one of the other 15 amps in its place and it worked!! So now the only thing I don’t know is WHY it went?? Thanks again for your help and I really do appreciate your and the other members for their help. Joe
Posted: 25 Jun 2018 at 9:05pm |
I'm glad you got it fixed. It is surprising to me too that it was blown and the light was not on to indicate it. Electrical problems can be very frustrating.
