  New Posts New Posts RSS Feed: Tail light replacement
Topic ClosedTail light replacement
crankster78 View Drop Down
Direct Link To This Post Topic: Tail light replacement
    Posted: 30 Jun 2018 at 8:33pm
Greetings
I posted about my taillight LED's going out a couple of years back.  I got new taillights from the dealer and used silicone caulk to seal them.  I found that the led's that failed had thick white caulk attached to the back of the taillight in the failed areas causing them to overheat from what I could tell.   You can buy high quality silicone from any RV dealer.
Crankster78
Crankster 78 R-179 2015
craigwood View Drop Down
Direct Link To This Post Posted: 28 Jun 2018 at 8:52pm
Thanks!  What adhesive/caulk should I use when I am installing the replacement tail light?
Pod People View Drop Down
Direct Link To This Post Posted: 27 Jun 2018 at 8:36am
I purchased a set of extra tailights from etrailer and they match perfectly.they are item STL43rbx and cost $18.48 each.
Vann
Vann & Laura 2015 RPod 179
mcarter View Drop Down
Direct Link To This Post Posted: 26 Jun 2018 at 4:54pm
I would contact FR, their tech support is very helpful and will lead you in right direction. BTW Command has a website and that particular light is $20.95. Google is your buddy.
Direct Link To This Post Posted: 26 Jun 2018 at 4:42pm
Anyone out there know where to purchase a replacement tail light?  A few of the LEDs (L1, L2 & L3)are always out and it frequently stops blinking altogether when I have the turn signal on.  It is a Command 003-6019 with other numbers 170-35.  Any suggestions would be appreciated!  It's for our 2015 179.
Thanks in advance!
