Post Reply | Page 12> |
hogone
Senior Member Joined: 09 Apr 2013 Location: St. Louis Online Status: Offline Posts: 1040 |
Topic: !@#$$% ? Posted: 07 Jul 2018 at 6:59am |
i have about 15 gallons in the black tank, forgot to dump, and probably wont be going out for another month. anyone ever drain in a bucket and dump in home toilet? stupid idea and just let it be or go for it? hogone
Jon & Pam
Awchief
Groupie Joined: 04 May 2018 Location: Biloxi, MS Online Status: Offline Posts: 83 |
Posted: 07 Jul 2018 at 7:14am |
Could be interesting. Video and post outcome.
Michael
Posted: 07 Jul 2018 at 7:44am |
hogone,
I have cleaned a black tank at home and did use a bucket and an old strainer, the main thing I got was TP. There was an old post on here about an owner who drained it on his large property, but I wouldn't recommend that. If you have sewer access, like a clean out you can also dump it there. I have a septic, so that is not an option. We have several RV parks in the area, that I'm sure for a fee would let me dump, may want to check into that. |
hogone
Posted: 07 Jul 2018 at 7:50am |
i just dont feel like hooking up and dumping!! closest place is probably 30 miles. gonna give it a shot. i may be halting quickly though!! report to come. hogone
Jon & Pam
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6283 |
If you are using a biological tank treatment like TankTech's Rx, Unique Products' Digest-It or other similar treatment, just let it be until you go out again. It won't hurt a thing. In fact, that is what TankTech's recommends. Otherwise, are you on a septic tank or on city sewer? If on city sewer and you have access to a 3" drain (may be a pipe sticking up with a white screw-in cap), you could just get sufficient drain hose to reach and dump there. I have two drain fittings in my yard. One is near the foundation and the other is out near the property line. I verified that it is the drain by flushing the toilet inside and observing to see if the water flow reflected that flush. Once I was sure it was indeed a sewage pipe and not a storm drain, I went ahead and just use that instead of searching out a dump station. After all, I am already paying for water and sewage every month. |
hogone
Posted: 07 Jul 2018 at 8:09am |
I didnt think we used it that much, only got 5+ gallons out. gauge must be stuck as it reads still at half. I know there not all that worthy!! gonna go hook up black tank flush. stay tuned. and it really wasnt as bad as i thought. hogone
Jon & Pam
lostagain
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2583 |
Posted: 07 Jul 2018 at 8:17am |
I've drained the tank several times with a 5 gal. bucket and dumping it out in a toilet. It makes the bathroom smell pretty badly so I always turn the vent van on and clean up throughly afterward.
BUT, our situation is a little different from what you describe. Our tank has never been anywhere near full, always less than 5 gallons; and, it contains no solid waste, no paper or #2. With my first boat, I had a porta-potty that I regularly dumped in a toilet, but it only held about 4 gallons and had handles and a smaller dump port so it was easier to deal with than a plain old bucket; still an unpleasant experience, though. Personally, if the tank was contained more than about 4 gallons of waste, contained paper, or had solid waste in it, I would make the effort to drive to a dump station and pay the fee. Fortunately for us, we live near a Maverick gas station that offers free dumping. If i was in need of urgent dumping, I'd go there, buy some gas and dump away. |
Posted: 07 Jul 2018 at 9:07am |
Yes, don't trust the gauge. It is not to be believed. Mine has read full even after I emptied it. Bits of paper and other items hang up on the sensor probes and give false readings. There are other probes that have a shield over the top part to keep stuff from accumulating on the probe but the best solution I have read about is the SeeLevel that reads through the wall of the tank and is not affected by the contents. However, it isn't cheap. I just saw another version on Amazon by Levelguard called SensaTank that looks similar and also reads through the tank and should therefore be much more accurate. I may have to get one or the other one of these days.
hogone
Posted: 07 Jul 2018 at 9:14am |
mission complete!!!! clean as a whistle. never done this before, so actually watched what came out. Obviously things break down very nicely, nothing but stinky brownish water, no solids or t paper. ran black water flush for about 10 minutes, you could drink out of this thing. one thing i noticed was alot of dead black flies. is that normal? hogone
Jon & Pam
dr2428
Groupie Joined: 13 Aug 2016 Location: Nebraska Online Status: Offline Posts: 70 |
Posted: 07 Jul 2018 at 9:25am |
I'm only a few years into campers so no expert but I'd agree with StephenH, I been adding 5gal and a biological after dumping and find it cleans well sloshing around on the ride home. Not wasting tank space as I would have added 5-6 gals with my chems at my next trip anyway, I just show up with it.
I've also considered a mascerating pump for home use, there are cheaper models than this. Would be useful if I use the 179 as a guest room in the driveway. https://www.amazon.com/Flojet-18555-000A-Portable-Macerator-Carrying/dp/B001HKZHIW/ref=sr_1_2?ie=UTF8&qid=1530972847&sr=8-2&keywords=black+tank+pump#customerReviews |
2017 RPod 179
2018 Chevy Colorado Z71 4x4 |
