  New Posts New Posts RSS Feed: Electric brakes
Topic ClosedElectric brakes
Vector1952 View Drop Down
Direct Link To This Post Topic: Electric brakes
    Posted: 12 Jul 2018 at 6:34am
Has anyone had problems with their brakes staying on?  Drove 17 miles, could feel the brakes, felt like I was dragging the wheels.  Noticed 2 wires not connected so my electrician son re-connected the wires near the axle now it is free wheeling again until I apply the brakes, they squeel! Any suggestions?
Xxxx7
mcarter View Drop Down
Direct Link To This Post Posted: 12 Jul 2018 at 8:30am
I would suggest you have brakes inspected or do it yourself if capable. If the brakes locked on or made constant contact with hub, they would generate heat. The heat can cause the shoes to "glaze". The shoe surface is hardening and crystalizing. That shiny, smooth surface could cause the squealing you're now hearing. There can also be some residual material between the shoe and hub. Old timers would clean the hub and sand the shoes, most shops nowadays will just replace the shoes.
mjlrpod View Drop Down
Direct Link To This Post Posted: 12 Jul 2018 at 9:18am
I had trouble with my brakes when i first bought my pod. After driving a little while, if i put my brakes on, it seemed like they wouldn't back off. One side, the door side, seemed to be the culprit. I brought it back, and they found nothing wrong, but I found a rivet or something that stuck up a tiny bit, and told them I think that might catck the brake shoe. They agreed and swapped it out for free (warranty) and its been fine
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 12 Jul 2018 at 1:26pm
Thanks mike, taking your advise...my soninlaw has a friend who owns a garage, going there tonite...told me to stop at tractor supply for drums and brake kit...will take a look at drums and shoes...if not needed will return...
Xxxx7
Direct Link To This Post Posted: 12 Jul 2018 at 4:13pm
Let us know how that works out. The drums are probably ok, the shoes will be glazed.
