Noisy Dometic AC - Event Date: 14 Jul 2018 - 21 Jul 2018 |
Post Reply | Page <1 234 |
Calendar Event: Noisy Dometic AC Posted: 16 Jul 2018 at 3:40pm |
Post Options Quote Reply Posted: 16 Jul 2018 at 12:17pm |
This one is called "Quiet Kool". 5,000 BTU, and sound rated at 55 dBA. On a 179, you could chop out part of the kitchen window and paste it in.
Richand Cindy
Senior Member Joined: 16 Apr 2016 Location: New Jersey Online Status: Offline Posts: 328 |
Post Options Quote Reply Posted: 16 Jul 2018 at 11:04am |
On our new RV we have a curved ceiling and ducted A/C. It still is noisy but nothing like the RPOD. At 13.5 BTU the rpod A/C is way too big unless you camp in 100 plus degree weather. I did hear of someone (not a RPOD) getting a small casement size 4000 BTU unit and putting it in a window opening. That would be quieter but again not cost effective unless your a/c breaks and you need a new one anyway.
NEW: 2018 Passport Elite 23RB + 2017 Ram 1500 Diesel |
clickscrazy
Senior Member Joined: 09 Aug 2017 Location: FL Online Status: Offline Posts: 106 |
Post Options Quote Reply Posted: 16 Jul 2018 at 7:52am |
I am going to have to try the foam on the inside shroud. I assume you mean on applying foam on the inside of the white plastic piece with the vents?
2018 R-Pod 171
2014 VW Touareg TDI |
Post Options Quote Reply Posted: 15 Jul 2018 at 3:36pm |
My parents had a motor home. The non-ducted AC in their much more expensive RV was not any quieter than the one in the R-Pod. Yes, there are smaller units. Look on Camping World's web site and you can see the options. Are any of them cost effective? I doubt it. I don't think you could sell your existing unit for enough to make purchasing and installing a different unit economical.
Post Options Quote Reply Posted: 15 Jul 2018 at 2:24pm |
Stephen just told you the truth: ANY air conditioner that opens directly above your head is not going to be whisper quiet. A smaller unit operating the same way will not be much quieter. I think that putting a duct system in will cost way to much for the average owner. And if you can afford the cost then you would be better off with a different (much more expensive) RV. Or better yet hotel reservations.
1Hpod
Newbie Joined: 25 Aug 2017 Location: Baltimore, MD Online Status: Offline Posts: 22 |
Post Options Quote Reply Posted: 15 Jul 2018 at 10:15am |
THX
I appreciate the suggestions. If anyone has actually replaced your unit with a quieter unit I would be curious to know the make and model of the replacement. And the big question is do you feel it was worth The expense for the sound reduction in benefits gained? |
H&Rpod
'16 179 Tow '15 Ford F 150 FX4 |
Post Options Quote Reply Posted: 15 Jul 2018 at 8:52am |
Unfortunately, with a non-ducted AC, there is not much you can do to quiet it down. There are a few things though. First, close the big vent and use the front, back, and side vents. That will make it a little quieter. Second, run the fan speed on low instead of auto or high. That will also make it a little quieter. Plus, it is easier to get used to a constant sound rather than the intermittent start/stop and speed switching of the auto setting. Third, and more difficult, remove the inside shroud. Be careful as there are multiple places where there are screws and not all of them are visible. Take some thin closed-cell foam sheet material and use spray adhesive to glue it to the inside of the shroud avoiding the track for the large vent and making sure not to block any of the other vents. Then replace the shroud. This will also cut the sound a bit. Last, since you have a 179 like ours, sleep with your heads toward the wardrobe side and your feet toward the slide-out side. The wardrobe will help block some of the noise. Hopefully, these suggestions will help.
1Hpod
Post Options Quote Reply Posted: 14 Jul 2018 at 9:24pm |
NOISY A/C
Has anyone had any luck with quieting the Dometic AC with in the pod? Can’t hear ourselves think let alone speak. It is very efficient, cooling rather quickly, but it is anything but peaceful. My wife has even inquired about the possibility of replacing it. |
H&Rpod
