Calendar Event: 2017 R POD 178 Actual height Posted: 02 Aug 2018 at 5:03pm |
Originally posted by mcarter
TMI - the Federal Highway Commission monitors design of highways and clearances. The minimum is 14' as detailed in Table 19. It covers multiple roadways and any issue has to be reported to DoD, the Military Surface Deployment Command and the Distribution Command. I recall an instance of traveling on a state highway from RI to NJ, a large sign directed all traffic over 9' to exit now. I did, and was correct the overpass would have taken the AC off my class C. |
Ouchie ouchie ouchie!
Posted: 02 Aug 2018 at 3:19pm |
Posted: 02 Aug 2018 at 3:02pm |
+1, I would try and check it out on something close to an advertised height, some spare clearance would be important. I can enter trailer height in my GPS and it warns me when I am approaching a clearance issue. BTW - I use 10'.
Posted: 02 Aug 2018 at 1:19pm |
Originally posted by wooleeman
I worked in a truck shop for many years and remember the box trucks and trailers that hit the bridges. I just figure on 10 feet. Easy to remember and allows for those bridges that just had the road resurfaced under them and measurement not changed. |
Never worked in a truck shop, but I remember when I read about our R-pod and remember 9 feet plus some change (maybe around 9.5 feet). At any rate, instead of remembering what the change was, I just made a mental note of 10 feet. If you have 10 feet, you should be good.
The Hood River pods have 15" tires and are about 3" higher off the ground. So there is that too.
wooleeman
Posted: 02 Aug 2018 at 12:26pm |
2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
mjlrpod
Posted: 01 Aug 2018 at 8:48am |
My pod absolutely measures 9 foot 2 1/2 inches over the A/C unit (I remeasured). I assume not all pods measure the same. It could easily fluctuate a couple inches. I have 14 inch tires, so the newest pods are going to be higher with 15 inch (i assume they didn't lower the roof to accommodate new tires). I don't know if the "hitched height" changes it either. I think 9 foot 7 inches might be a smart number to use as a minimum. (just a side note: 9.6 is not the same as 9'6")
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted: 01 Aug 2018 at 8:27am |
Forest River latest specs for a 172 is 9.6", might make a difference if you have 14" tires. New models have 15" tires.
mjlrpod
Posted: 01 Aug 2018 at 8:23am |
Hmmmm I believe my pod is 9 foot 3 inch. I better recheck this number, before I have a 4 inch mishap
2020 R-pod 195
I'll be rpodding
Posted: 01 Aug 2018 at 7:16am |
Originally posted by Barryb
Thanks Mike;
I am new to the r pod world, do you know if the water pump is compatible with pumping water from a water container and into the fresh water holding tank?
Thanks Barry |
No it is not. For people who have such a need, buying a small pump, or using one powered by a cordless drill, and moving water works. Or just plain old gravity.
Barryb
Posted: 31 Jul 2018 at 6:58pm |
Thanks Mike;
Thanks Barry
