KIB monitor panel schematic / wiring diagram |
jimandclare
Groupie Joined: 13 Apr 2016 Location: Erie, MI Online Status: Offline Posts: 96 |
Topic: KIB monitor panel schematic / wiring diagram Posted: 06 Aug 2018 at 11:26am |
Great! Glad to be of assistance.
Jim & Clare
MadCity
Newbie Joined: 18 Aug 2017 Location: Madison, WI Online Status: Offline Posts: 14 |
Posted: 06 Aug 2018 at 9:38am |
jimandclare, That's exactly what I needed. I was able to successfully install the SeeLevel using the existing wires from each tank. Install took all of about 30 minutes. Thanks!
2018 R-Pod 176T
2008 Honda Pilot AWD |
jimandclare
Posted: 04 Aug 2018 at 5:14pm |
MadCity,
Was going to attempt the same mod a couple of years ago so I bookmarked these links but just never got around to it. Below are the links that should answer your questions: (How the system works ... or should work) Troubleshooting the KIB monitor KIB Monitor Wiring Diagram (Download PDF File) Hope this helps
Jim & Clare
Posted: 04 Aug 2018 at 3:38pm |
I did a Google search on KIB wiring diagrams. GOOD LUCK. I have never seen a wiring diagram for anything in a Pod except for the 7 way and it was basic. I know I have built some wiring diagrams when working issues with my Pod.
MadCity
Posted: 04 Aug 2018 at 9:52am |
Does anyone happen to have the schematic / wiring diagram for the KIB control panel? This is on a 2018 176T (not sure how standard they are across rpods) I'm switching over to a SeeLevel II and would like to use some of the existing wiring at the panel. TIA!
2018 R-Pod 176T
