Floor Repair |
Post Reply | Page <1234> |
Topic: Floor Repair Posted: 08 Apr 2022 at 6:08pm |
It will be a challenging project. Everything above the plane of the floor is mounted on the floor, so replacing the floor is a bit like replacing the foundation of a house. Here are a couple videos of how they are built that may help in coming up with a repair strategy. The second video is from a 2014 build, which is really not much different from the 2015. Good luck.
cbardy58
Newbie Joined: 25 Sep 2021 Online Status: Offline Posts: 6 |
Post Options Quote Reply Posted: 08 Apr 2022 at 3:47pm |
Hi Denis,
I have a 2015 178, which I bought last fall. I found a very soft floor in the rear under the bed and pull the linoleum up and found rotted plywood. I also pulled a small piece of the foam out and the underside is rotted too. I imagine I will need to replace the sub floor, on top and under, from the slide out to the rear. Do you have any help on how to go about doing this? I am a pretty handy guy and can handle just about any project. I have a plan in mind, just thought I would get advice from someone with experience. Thank you!
ChewadaJ
Newbie Joined: 03 Jul 2020 Location: Southj Carolina Online Status: Offline Posts: 18 |
Post Options Quote Reply Posted: 13 Sep 2020 at 12:19pm |
Denis, I'm attempting a similar repair on my rpod. The whole top layer of plywood is pretty much worthless. I can tell from underneath where the bellyboard (black waterproof layer, not sure what else to call it) has come loose, the bottom layer of plywood is rotten in a few spots, but not all over. I have several questions about how you worked around the bolts joining the floor to the frame, how you put the bottom layer of plywood back in, etc....Could I contact you through DM or give you my number to give me a shout sometime? Thanks in advance! |
DenisP
Newbie Joined: 23 Dec 2017 Location: Massachusetts Online Status: Offline Posts: 15 |
Post Options Quote Reply Posted: 25 Oct 2018 at 7:01pm |
I purchased a 2010 171 last December and found that once the weather warmed and the floor thawed we had a "soft floor". I removed all the linoleum flooring and placed a large dehumidifier in the R-Pod and dried out all compartments. I found the floor was delaminated in many areas due to multiple access points. I fixed all the leaks including the basement doors, the shore power outlet and the largest repair was the front seams bottom and sides with larger fasteners. I removed the delaminated luan plywood and in main areas down to the membrane. I added stainless steel braces, cedar stringers, and replaced the plywood with epoxied luan and the foam with rigid foam panels. Once the floor was reinforced, subfloor replaced where needed I added additional epoxied plywood before adding waterproof vinyl plank flooring.
The end result was a stronger, very dry R-Pod which was attractive and should last for many more years. The repair exceeded $600 in materials and approximately 80 hours. My experience with boat repair and construction methods was very helpful. I would be willing to share more specifics outside this forum. First and foremost finding the source of the water and sealing the R-Pod must be done or any repair work will be for nothing in a short time frame.
T@b 400 with solar
Formerly 2010 171 2013 Tundra TRD |
Racerdad
Newbie Joined: 18 Oct 2018 Location: ON Online Status: Offline Posts: 10 |
Post Options Quote Reply Posted: 25 Oct 2018 at 4:09pm |
Thanks everyone for the encouragement and when I start I will take pics to document the process. Time to consider a vacation... somewhere hot and no brain strain
crw8sr
Senior Member Joined: 12 Oct 2017 Location: Omaha Nebraska Online Status: Offline Posts: 328 |
Post Options Quote Reply Posted: 25 Oct 2018 at 2:25pm |
Oh.......and good luck.
Chuck & Lyn
crw8sr
Please take plenty if pictures and document your process; it could help someone else tackle the same problem and other members maybe able to give advice.
Chuck & Lyn
Post Options Quote Reply Posted: 24 Oct 2018 at 5:25pm |
Best of luck. your favorite adult beverage might help
Racerdad
Post Options Quote Reply Posted: 24 Oct 2018 at 5:07pm |
Will start adventure tomorrow
Post Options Quote Reply Posted: 24 Oct 2018 at 3:51pm |
Racerdad,
I think first thing to do is remove items on the wet area. I agree water wicks, which to me means cabinets and seating structures, wall areas. The floor can dry once you to where you have eyes on it and the wet areas. Hard to remove the wet floor with cabin structures in place. |
