Floor Repair |
Post Reply | Page <1234> |
ChewadaJ
Newbie Joined: 03 Jul 2020 Location: Southj Carolina Online Status: Offline Posts: 18 |
Topic: Floor Repair Posted: 06 May 2022 at 1:29pm |
100% agree with the outriggers. I felt like drilling and bolting was easier than welding bc of having to move the black bottom. Good luck out there everyone!
Post Options Quote Reply Posted: 06 May 2022 at 1:07pm |
Id still suggest adding the outriggers under there, the wall loads need to be carried back to the frame rails, and half inch of plywood and a few thin pieces of floor metal wont do that. It's not the weight of a couple of people, it's the loads (and 2 plus g's bump loads) from the entire wall and roof structures and everything attached to them.
I agree with you about the rpod throw away design. Cheap and light but not something anyone should expect to last very long. One reason I sold mine since I wasnt expecting to be able to use it for a few years. I'd rather just get another trailer when I need one again rather than try to maintain one in storage for several years in a humid environment. |
ChewadaJ
Post Options Quote Reply Posted: 06 May 2022 at 12:45pm |
My solution was to use a thinker board on top that covered a larger area. I lost about a 1/2' of height. And secured the floor to the metal frame in several spaces, used some 2"x2"s where needed. Again, I was going for more shorter towing and I didn't have a garage to work in. The floor was stable for 2 people to walk on. No problem there. What I learned is that R pods are not meant to be repaired. Short term gain with them I think. Long term pain.
Post Options Quote Reply Posted: 06 May 2022 at 12:33pm |
The problem is that the floor structural strength resides primarily in the laminated plywood/foam sandwich, which acts much like a structural insulated panel (SIP). The floor metal framing is not where the strength is. So if water damage has compromised the floor panel the edges of the floor which cantilever out past the main rails (which are inboard) will sag under the load imposed on them by the walls.
Many folks have reported this problem abd some have even had the floor metal framing spot welds break. So even if you get in there and replace foam and plywood you should add outriggers underneath to support the floor. There isn't any way to effectively recreate the laminated sandwich construction of the original continuous floor when patching in foam and plywood. Probably it would be as effective and much easier just to jack up the walls and floor till things are level, install outriggers and underfloor bracing as required, pull up the vinyl, let the floor dry out, then lay down a new layer of plywood, new finish flooring, and be done with it. You can use a moisture meter to ensure the old floor is dried out. Even in the southeast running the air conditioner and a space heater simultaneously (so the air in the trailer has as low humidity as possible) for a month or so ought to do it. |
ChewadaJ
Post Options Quote Reply Posted: 05 May 2022 at 8:49am |
True, but when I tore up the floor, I saw the metal framing around each section. The walls are famed, as is the floor The frames touch each other. So I was able to rip up everything and replace the material between the metal frame sections.
marwayne
Post Options Quote Reply Posted: 04 May 2022 at 6:29pm |
When FR gets the undercarriage the first thing they do is put down the floor, the lino then the walls. If they put the walls up first, the floor would be floating all around the perimeter.
ChewadaJ
Post Options Quote Reply Posted: 04 May 2022 at 10:59am |
To some degree yes, but the walls sit on the frame, and the floor is connected to the frame. I don't remember the walls sitting on the floors. What I did was tear out off the floors and the walls half way up the walls in the back to find the leak (rear window of course) and to get it dry. I am in the SE, so that's the hard part when I don't have a car port to put it under. It took forever. I found some thin laminate I was using for the wall replacement, with new insulation behind it. For the floors, I put in new press styrofoam. Then put a 1/4' ply wood over the top of everything. My plans was to weld some metal supports, or maybe bolt some supports in below for extra support since the floor wasn't as firm as before. But the foam and plywood seemed to work. I had a leak up front too on the seams on the sides, so I had to take out the walls on the curved front wall. That was going to be tricky. Between having it i storage that was 20m away, no power, no cover, not enough time...I just couldn't finish it. I sold mine to a carpenter who was set up for the project much better than me. I did all the hard work though of sealing it all back up and tearing out all the mold! It's doable to fix them. I'm not sure if I'd take mine cross country until I saw how it went on short trips. I bought mine used, and it didn't figure out the leak situation until much too late. It was in really bad shape. I think I deleted all my pictures of the project already unfortunately. I'm happy to talk you through what I did if you want to chat sometime.
Post Options Quote Reply Posted: 04 May 2022 at 5:45am |
If you have significant floor damage/sagging around the perimeter you have to find a way to lift the walls off the floor and replace the lauan plywood in the floor sandwich. I don't know any other alternative because the floor sandwich supports the walls. Granted that its not fun or easy.
cbardy58
Newbie Joined: 25 Sep 2021 Online Status: Offline Posts: 6 |
Post Options Quote Reply Posted: 03 May 2022 at 10:48am |
I am in the exact same boat and looking for solid info on how to go about the repair. The FR videos on "floor" construction do not help.
ChewadaJ
Post Options Quote Reply Posted: 08 Apr 2022 at 6:12pm |
Denis, it's a pain. I got 50% through the rebuild and sold it cheap because it was a bigger project than I could handle, having to store it in a lot where I had to drive to work on it. You have to fine where the leak came from. In the rear, my guess would be the window. That means you'll have to take off the wall partially too. Get a humidity tester. Get it under cover, and find the leak. Then start ripping it down to the bones. You might not need to rip out the foam and subfloor if not to damaged. The thing to remember is how the R pod is built. The floor is a plyboard/foam/plyboard layered thing that is glued together for lightness and strength. Anything you'll do won't be as strong, so you'll need to build it back a bit better. Let me know what other questions you have, and good luck!
