Winter |
Post Reply | Page 123> |
mjlrpod
Topic: Winter Posted: 12 Nov 2018 at 4:30pm |
So I called to arrange my storage space for my pod, only to find they are filled up. So I decided the pod is staying home for the winter. So many people are buying campers it's going to get to where you're going to have to pay year round to keep the spot. I am just checking to be sure it's ok to leave the battery in for the winter? I will either be plugged in all winter, or even if I unplug, I will make sure i plug in every 3 or 4 days. I kinda like knowing i have an emergency pod outside if needed.
2017.5 Rp-172
GlueGuy
Posted: 12 Nov 2018 at 4:49pm |
We have done both. I'm 1000% happier with our R-pod at home when we're not camping. We keep ours plugged in most of the time here. When we had it in storage, we would pull the battery. I would imagine that you wouldn't need to plug it in that often. Once every couple of weeks, or maybe even once a month should be sufficient.
Ben Herman
Senior Member Joined: 26 Apr 2018 Location: Gr Junction, CO Online Status: Offline Posts: 355 |
Posted: 12 Nov 2018 at 6:21pm |
I pull mine, put it in my garage shop with a trickle charger. I occasionally check the water level in the battery. Oh, and I have a cover for the pod.
Tars Tarkas
Posted: 12 Nov 2018 at 7:43pm |
We keep ours at home and keep it plugged in. No need to remove the battery -- it's constantly being trickle charged by the on-board charger/converter. With power we don't have to clean out and turn off the fridge. Could, of course, but it doesn't use enough juice to worry about. That's about it for power useage. The battery is always topped off and ready to go. And added advantage to having power is that we can plug in a heaer and get a little more flexibility regarding winterizing. We get out with the pod at least a couple of times in the winter. TT
FJ Cruiser |
Posted: 12 Nov 2018 at 8:39pm |
+1 to Tars Tarkas on leaving the battery connected. If you have power available and are keeping the pod at home, just leave it plugged in. No need to disconnect the battery, buy and keep a separate trickle charger on it or worry about parasitic loads in the trailer. The charger is designed to maintain it just fine at the proper state of charge. Check the water level every couple of months and keep the battery plates covered with distilled water.
Personally I wouldn't recommend keeping the fridge running as that heats the ammonia refrigerant which will accelerate corrosion of the refrigeration tubing. Eventually these absorption type fridges typically die from refrigerant leaks or blockage caused by corrosion of the tubing.
Posted: 12 Nov 2018 at 8:55pm |
We have stored ours at home since purchasing in Janaury 2011. Since power is not available in the barn where we store it, both batteries come out and sit on the concrete floor in our unheated garage. This is usually done near the end of October and I will check the water level before giving each a 2 amp trickle charge for a day. I then leave them alone until the following April where I repeat the process. The batteries are nearly 8 years old (group size 24 12volt deep cycle) and still perform very well. Will be interesting to see how many more years they will last.
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 13 Nov 2018 at 1:46pm |
I'll pull my battery out soon and put in the unheated part of my basement, where it never get really too cold. The Pod itself stays hooked up to 120V power so I can work inside it if I wish. Then come spring, check water level in the battery and put it on a slow 2 amp charge for a day before reinstalling.
Posted: 13 Nov 2018 at 4:08pm |
My Pod is in the building, hooked up to 120, use the converter to maintain charge. I don't remove the battery and I don't run fridge.
Lipman
Newbie Joined: 29 Oct 2018 Online Status: Offline Posts: 1 |
Posted: 19 Nov 2018 at 3:31pm |
Posted: 19 Nov 2018 at 3:40pm |
I can't think of any reason I would run a fridge in a Pod in storage? It is empty, I have no use to cool anything in the Pod. The sole reason it is plugged into AC is to maintain battery charge.
