Weight Distribution Towing |
Post Reply | Page <12345> |
Author | ||
john in idaho
Topic: Weight Distribution Towing Posted: 04 Dec 2018 at 10:20am |
Looking at the photo, it would appear that there is too much weight on the rear end of the tow vehicle. But that is just from looking at the photo.
MIK
Groupie Joined: 09 Jul 2017 Location: MA Online Status: Offline Posts: 42 |
Posted: 12 Dec 2018 at 1:10pm | |
I have one. It's my first camper, so I don't have anything else to compare it with, but it works fine with my tacoma. Got around 5K miles on it so far. |
2018 R-Pod 180
Posted: 14 Dec 2018 at 3:35pm | |
Hard to tell from the original photo, but ultimately the camper should be level or slightly nose-down, and typically the rear of the TV will be slightly lower than when unhitched, and the front will be about the same as when unhitched.
AL1010
Newbie Joined: 31 Oct 2018 Location: NC Online Status: Offline Posts: 29 |
Posted: 25 Dec 2018 at 7:11am | |
Did you shorten the shank? I need to do that for our 4Runner. I can’t get the the 2nd hole without removing the spare tire.I just got mine towed about 20 miles seem good.
AL1010
Posted: 25 Dec 2018 at 10:48am | |
It does lift the rear of the TV when you tighten the chains. It is much quieter and smoother than the std.WD system I was using.
MIK
Posted: 25 Dec 2018 at 3:01pm | |
I removed 2 links from the chain otherwise it wouldn't fit where I needed it to be. I think, per installation instructions, you can remove up to 4 links. I might need to remove another one. |
2018 R-Pod 180
ToolmanJohn
Posted: 26 Dec 2018 at 6:50am | |
The Andersen works as intended. I had one for over a year and it definitely settled down heavy bounce over expansion joints. No more oscillations at all. Just make sure that you measure the ball height as directed in the setup instructions (starting about 1 to 1-1/2 inches higher than the trailer coupler). Then make certain it is sagged slightly lower than the original couple height so the trailer is ever so slightly nose down. That final adjusted position is ideal. Don't remove all the sag by tightening the chain adjuster.
AL1010
Posted: 02 Jan 2019 at 7:37am | |
Did either of you have a lot of slop in the shank?
Posted: 05 Jan 2019 at 8:55am | |
Sorry for my belated reply, I'm only just now getting back on the forum after an extended family emergency.
StephenH, a WDH is generally considered to be part of the tow vehicle not the trailer, because it winds up being rigidly attached to the TV receiver when in use. I don't think the Hensley hitch is different in that regard. But of course, since a WDH acts to redistribute tongue load to the TV front axle and trailer axle, its weight doesn't end up on the TV rear axle anyway, like tongue weight does if you don't have a WDH. |
Posted: 05 Jan 2019 at 9:57am | |
