Bent axle question?? |
Post Reply | Page 12> |
Pod People
Topic: Bent axle question?? Posted: 29 Nov 2018 at 6:17pm |
I have read several [posts about bent axles. A post last week mentioned using a string line to check from end to end to see if it was bent. Maybe this is a dumb question, but IF the axle is bent, does it bend up or down in the middle? Seems like since the weight is on the outer edges, that would push down which would make the center push up???? but I can also see the other part --the axle bending down from over weight issues. So, is a bent axle bending up or down in the middle? Thanks Vann ps--I hope I don't need this info
Posted: 29 Nov 2018 at 6:56pm |
Looking at it logically, if the tires are tilted inward at the top (/-----------\), then since the supports for the axle are not at the joint of the axle and the pivoting arm, there is upward force on the portion of the axle on the outsides of the frame. This would have the tendency to move the portion of the axle between the frames downward. Thus, the axle would look more like a smile than a frown. However, the owner's face would be more of a frown than a smile if this situation occurs. I heard from the dealer. The update was, "We have measurements sent up to LCI and are still waiting on a response."
GlueGuy
Posted: 29 Nov 2018 at 7:21pm |
It also might not bend in one place. It's possible that the portion of the axle that is outside the frame (on both sides) could get bent. Then it could be more like this (hope this works): | | |\___________/| | |
Posted: 29 Nov 2018 at 8:02pm |
True. It might be bent on one side outside the frame without disturbing the other side if the cause of the bend were something like hitting a curb or a bad pothole.
Pod People
Posted: 29 Nov 2018 at 8:12pm |
Thanks Stephen. I can easily see your description. I know you have first hand knowledge,unfortunately.
I hope your situation resolves itself without your wallet lightened too much. Good luck Vann
Posted: 30 Nov 2018 at 6:00pm |
Posted: 06 Dec 2019 at 4:59pm |
I never did update this. I did end up getting the axle replaced (I had to pay for it). We picked it up in January of this year. My wife had surgery, so I was not able to get any use out of it until we went to the Carolinas Pod Rally. Then the weld that holds the brake backing plate to the axle broke on the way there. I had a technician remove the brakes on that side so we could get home (I drove even more carefully than I usually do, allowing more space between me and traffic in front of me). I contacted Lippert, and it was replaced under warranty Lippert also reimbursed me for the labor costs involved. Big kudos to Lippert!. The work was done at a dealer that is only a few minutes drive from me rather than at at the dealer where we purchased our RPod which would have been a 2-1/2 hour drive. The dealer that did the work does not sell RPods though. It would still be at least a 2-1/2 hour drive to get to the nearest dealer that does sell RPods. The original dealer stopped selling them. . So far, the new axle is working well. We just got back from a trip to Florida and will be headed that way again soon.
lostagain
Posted: 07 Dec 2019 at 12:34am |
That was one of the factors that led me to get the Sonoma instead of a little bigger r-Pod. Unlike the cantilevered axels on the r-Pod, the axles are mounted to the frame right next to the brake backing plate on leaf springs attached to I-beam frame rails. The axle is still a 3500# axle uprated to 3900 by Lippert through the use of heavier leaf springs. I guess only time will tell how it will hold up.
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 07 Dec 2019 at 8:17am |
My assumption here is you have an indicator of an issue. Curious what you're looking at? Mine was a tire camber on the drivers side. Being only one side showing this and little bend to the axle, I finally found the issue. My frame was bent (actually fractured). Hopefully not what you have.. If there is an issue it will be seen where the axle mounts to the frame. |
Toyanvil
Senior Member Joined: 15 Feb 2019 Location: Bakersfield Online Status: Offline Posts: 157 |
Posted: 07 Dec 2019 at 8:49am |
The best way to check your axle is with a 24" bubble level. The wheels should be the same as the side walls of the trailer, it's that easy. Just check the plumb of the wheels and then move up to the wall, should be the same. The axle arch should be different trailer to trailer, they bend the arch to align the wheels.
