  New Posts New Posts RSS Feed: Bent axle question??
Topic ClosedBent axle question??
Pod People View Drop Down
Direct Link To This Post Topic: Bent axle question??
    Posted: 07 Dec 2019 at 4:24pm
I haven't found an issue-I was just curious and trying to find out what to look for and how to determine IF there was a problem.
As always, this forum and its members are a wealth of information and happy to help.
Thanks
Vann
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 07 Dec 2019 at 9:39pm
There were photos posted on the forum this last year by someone who had the problem.
There would be two possible clues.
1 - The wheels will be cambered "out" at the bottom. Depending on how bad it is, this may or may not be visible
2 - If you stretch a string from opposite sides at the bottom of the axle, there should be 1/4" to 3/8" camber in the axle. This would take two people laying on the ground, but it would be a positive test.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 08 Dec 2019 at 7:29am
I'll add to this.. Watch your tire wear. If wearing majorly on a side, there's an issue.
Inside edge: Your running heavy and probably an axle/frame issue.
Middle: Over inflated for the weight carried.
Both edges: Under inflated for the weight carried.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 11 Dec 2019 at 6:34am
If you’ve got a heavier rPod and you’re concerned about bending the axle I recommend reinforcing it before you have a problem. I was and I did, cost about $100. Search for “axle reinforcement” and you’ll find several solutions folks have done.
