Power to R-Pod 179 - Event Date: 10 Dec 2018 - 20 Dec 2018 |
jonskipro
Newbie Joined: 22 Oct 2017 Location: California Online Status: Offline Posts: 7 |
Calendar Event: Power to R-Pod 179 Posted: 10 Dec 2018 at 7:19pm |
I've covered my R-Pod for the winter and winterized it. I still have power connected to the R-pod. Is this necessary?
Jon M
CharlieM
Posted: 10 Dec 2018 at 7:59pm |
If the battery is still connected then yes. If the battery is disconnected but still on the Pod you can disconnect the power but reconnect it and the battery for a day every two months. You are trying to maintain a charge on the battery. If the battery has been totally removed there is no need to maintain power on the Pod.
DavMar
Senior Member Joined: 04 Aug 2017 Location: Lexington, NC Online Status: Offline Posts: 592 |
Posted: 10 Dec 2018 at 8:43pm |
I take the battery out of my Pod and store it in my basement over the winter which is probably over kill considering of where I live. I also keep 120VAC shore power to the camper all winter only because if I want to do some work in it I have lights. If you don't see yourself working inside your Pod then there is no need to have shore power to it.
Posted: 11 Dec 2018 at 6:59am |
If it has power all winter long, there is zero reason to remove the battery. In fact, any time you remove it, you add to the possibility of having a 12v issue from either a shorted battery lead, or accidental reverse polarity when reinstalling. In a dozen years, We have never removed our camper batteries for any reason other then mods or replacement. We have FHU's at home.
Posted: 11 Dec 2018 at 8:34am |
+1 to the above. I did install a battery cut-off switch, but that is for times I have to disconnect the battery when it won't have shore power. It is at the dealer's still and the switch was off when I left. When we go to pick it up, the switch will be turned back on and then left on as I installed a 30A RV outlet so our 'Pod can stay plugged in.
crankster78
Senior Member Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Posted: 11 Dec 2018 at 7:51pm |
greetings: Here in MN it can get to -30 so even though I have a 30 amp plug, I take out the battery and put it on a "smart charger" for the winter. I have a grp 27. Crankster R-179 2015
Crankster 78 R-179 2015
CharlieM
Posted: 11 Dec 2018 at 8:04pm |
If a lead acid battery is charged it has a freezing temp of -80F. If the Pod onboard charger works it should maintain the charge. That said I suppose it's valid to question whether the WFCO charger will indeed work at -30F. As long as it doesn't stay at -30 it should be OK.
