GVWR>GAWR and Stabilizer Issues |
Post Reply | Page <1 34567> |
Author | |||
Topic: GVWR>GAWR and Stabilizer Issues Posted: 08 Jan 2019 at 7:05am |
Nope, you can't weld to torsion axles. There are rubber cords inside there that would burn up.
When Lippert and Dexter make them all the welding is done before inserting the rubber. The rubber cords are compressed and frozen (in liquid nitrogen I think) then everything is inserted and allowed to warm up.
The axle ends bend up under load, the center section of the axle between the frame attachments bends down. |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6283 |
Posted: 08 Jan 2019 at 7:43am | ||
It would be nice if there were such a thing as a V bolt used with a V plate, washers and nuts. I don't know if such a thing exists, but it would make things easier, I think.
When I look at the new axle, I can see a little upward bend in the middle section. Would an angle iron need to be bent to match the initial shape of the axle? Would adding a straight piece of angle iron tend to start a bending stress on the axle if an initial matching of the shape is not done?
I saw the 3/8" deep nuts and washers offered as an option. I like the idea of the deep nuts as they would have more threads.
lostagain
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2583 |
Posted: 08 Jan 2019 at 8:10am | ||
ummm, errrr, I just went out into the pre-dawn chill to confirm what I recall, that my axle is round. I was actually thinking of standard U bolts, not square ones like you'd find on a leaf spring. The round part would rest against my round axle and the retainer plate passing over the angle iron. The issue I had with that was that the retainer plate wouldn't fit up against the angle iron completely as it would have to be bent with a right angle in it to touch the angle iron and would need additional bends where the bolts go through at 45ยบ or so. Or am I, once again, trying to put round pegs into a square hole?
Another dumb question: Has anyone calculated the various potential sizes of angle iron and what additional strength they would impart to the axle once installed securely? For me, if I were to engage in such a modification, I would not be looking to significantly increase the load capacity of our 172, but to give it a little more strength for forest service roads and such when loaded within the defined limits. If I put a 1 1/2 inch angle with about 1/8th thickness angle iron would I be wasting my time or would it add enough strength to make it worth the bother. It's a lot of work wallowing around under a trailer for an old geezer my age.
Posted: 08 Jan 2019 at 9:33am | ||
StephenH, I've never seen a v bottomed U bolt but yes if there was one that would be good. Or you could weld up some custom clamps but I'm not convinced its necessary.
If your axle is crowned you'd probably want to crown the angle a bit to match. We'd probably have to ask a metal shop what that would cost to do. Angle iron gets bent all the time but I've mostly seen it bent parallel to one of the flats. I don't notice any crown in my axle but I haven't looked carefully. Could be mine has already started to fail, or its got more weight on it. About how much of a center crown do you have?
I calculated the 3/8 bolt size based on only a single thread engagement, so it's really way overkill even with standard nuts, but more threads can never hurt. lostagain, interesting that you have a round axle. Vikingr's 172 has pretty much the same axle as StephenH and I do. Who is the manufacturer? With a round axle you might be better off thinking about using a piece of steel pipe cut in half lengthwise rather than an angle to reinforce it. What is the OD of the round axle? You should be able to buy off the shelf u bolts to clamp it. I just looked at the 3 x 3 x 3/16 angle, which seems about right for reinforcing the 3 x 3 x 3/16 inch Lippert box tube axle, while not adding a lot of weight. Your case might be totally different, your configuration might or might not even be subject to axle failure. Have you had any signs of it?
Posted: 08 Jan 2019 at 9:41am | ||
I did find some online, but none of the correct dimensions for this purpose. I did not measure, but there was a little bit of crown visible. I don't think it was more than about 1/2", but I would really have to measure to be sure.
lostagain
Posted: 08 Jan 2019 at 9:55am | ||
My axle is about 3" inches in diameter. Since I broke my arm at the end of Dec., I'm in no condition to crawl under and measure it right now. I have no idea who the manufacturer is, except to say it's likely to be one of the two common brands. When the weather warms up and my arm heals, I'll take a gander below and see if I can find a label. Maybe I should just call FR and see what was originally installed. Since it's probably never been replaced, that should answer the question.
Where would I find a piece of steel pipe split in half without getting into going to a metal fabricator to cut one for me? Would the round half pipe configuration be sufficiently resistant to bending to make it worth it?
Posted: 08 Jan 2019 at 9:59am | ||
If you do go to the trouble to measure it I'd suggest lifting the trailer off its wheels first so you can get the crown dimension with the axle unloaded. Then if you crown the angle to match things should line right up under load.
lostagain
Posted: 08 Jan 2019 at 10:19am | ||
Sounds like a plan. But then I'd have to get the metal guy to not only cut the pipe, but to bend a crown into it? Right?
Posted: 08 Jan 2019 at 11:37am | ||
lostagain, it would depend on whether or not your axle was crowned. StephenH's is which makes me think that that is the way the Lippert ones are made. But your's and mine might no longer be crowned or yours might never have been crowned to begin with. If your axle isn't crowned and you're not getting uneven tire wear from too much negative camber then I wouldn't try to change its camber by strapping it to a crowned reinforcing element.
lostagain
Posted: 08 Jan 2019 at 1:42pm | ||
Thankfully, my tire wear is phenomenally even. It is easy enough to measure the crown, when the weather gets nicer and my arm recovers, simply by stretching a string from one side to the other.
