Freshwater tank - Event Date: 02 Apr 2019 |
Post Reply | Page 12> |
Author | ||
LEGZ
Newbie Joined: 30 Nov 2018 Location: FL Online Status: Offline Posts: 3 |
Calendar Event: Freshwater tank Posted: 02 Apr 2019 at 6:10pm |
2018 R-POD179 while hooked on city water noticing freshwater tank filling up. Next thing water coming out overflow vent hole at freshwater fill area. Emptied tank then filled freshwater tank through freshwater fill hole ran pump for couple minutes then drained tank. Filled tank through city water hook up and freshwater tank refilling still.
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2624 |
Posted: 02 Apr 2019 at 9:06pm | |
It's most likely the check valve in the water pump that is stuck or clogged. This link is a discussion of the issue.
Billy Bob
Senior Member Joined: 11 Jun 2018 Location: Boulder City, N Online Status: Offline Posts: 103 |
Posted: 03 Apr 2019 at 9:27am | |
+1 to glue guy....I had the same thing only a very slow leak from the pump into the fresh water tank. FR replaced it under warranty though I was told the pump itself is very inexpensive
2019 RPOD 190
2017 Chev Colorado 4 X 4 Yellow Lab and English Springer Spaniel |
LEGZ
Posted: 03 Apr 2019 at 5:12pm | |
When i find water pump does the whole pump need to be replaced if only check valve is bad, or can check valve just get replaced..
Posted: 03 Apr 2019 at 6:34pm | |
I think you can replace just the check valve, I'm not sure, but there's a good chance it's just stuck. You may have already fixed it by filling the tank and using the pump. Try hooking up to city water again and see if the tank still overflows. If it does, the tank is full, so just turn the pump on (and city water off) and cycle the water off and on a few times and try again. TT
FJ Cruiser |
Posted: 03 Apr 2019 at 6:59pm | |
You can replace just the valve, or do the pump head, both available on Amazon for a few dollars, takes a couple minutes. Just google your pump model number...
Posted: 03 Apr 2019 at 7:01pm | |
I went thru a year of this issue. Cycling is right answer, but it didn't work for me. I never could figure out why check valve was not working. Finally changed water pump and problem solved.
TheBum
Posted: 04 Apr 2019 at 10:45am | |
That "couple of minutes" is after getting to the pump, which is typically under the bed. Depending on your mattress choice and any provisions you've made to make access easier, that could easily double the time. |
Alan
LEGZ
Posted: 15 Apr 2019 at 8:22am | |
Took R-POD out for test run last weekend ran water pump for 4 days. Got home hooked up to city water, freshwater tank getting better not filling up but water still slowly getting into tank. So I will keep working check valve. Thanks
Posted: 15 Apr 2019 at 9:13am | |
"typically" the pump isn't under the bed.. but in the most popular model, the 179, it is. But yes, there may be time and effort involved in getting to the pump. .
