My version of axle support plan B |
Post Reply | Page <1234> |
Author | |||
marwayne
Topic: My version of axle support plan B Posted: 09 May 2019 at 5:27pm |
marwayne
Posted: 09 May 2019 at 4:13pm | ||
The tubing between the risers is 3x3 1/4" wall, The out riggers are 2 1/2 x 2 1/2 1/4" wall. I needed the extra space to get a washer and a nut in-between the axle and the outrigger.
SC for Huskers
Senior Member Joined: 22 Feb 2017 Location: Goose Creek, SC Online Status: Offline Posts: 144 |
Posted: 09 May 2019 at 4:05pm | ||
Marwayne, do you remember the size of the tube you used on the out rigger? Im thinking of getting a 2x4 riser and punching a diamond shape in it so as "Offgrid said" to go from end to end one piece. Then place all the hardware in the middle and ends. Input anyone?
Happy Traveling,
Tom 2017 172pod 2011 F150 STX |
Posted: 09 May 2019 at 9:38am | ||
[/QUOTE] Neither do I. The u-bolted 3x3 angle is about my limit. It does the same job, just doesn't look as pretty. Your failure was almost certainly the axle tube. The giveaway is not having any crown left in the tube. That is a bent axle tube. I'm not sure some of the other possible failure scenarios (say a bent torque arm) couldn't also cause negative camber though. And we have a couple of cases floating around where the tube doesn't appear to be bent or decambered but the trailer is sitting much lower on one side than the other. Those sound like maybe damaged rubber cords. The majority seem to be bent tubes though. |
Posted: 09 May 2019 at 8:18am | ||
What about a round tube as opposed to either flat or diamond?
If a round tube were used, could one drill through the existing riser and then weld the tube to the riser instead of building a new riser?
Since I don't have the skill to do this myself, I would be a customer for such an item. As for other points of failure, in my case it was the loss of camber. Bearing wear might have also had some part but the symptoms (excess wear on the inside edge of the tires and visual tilt of the tires when viewed from the front or back) led me to feel the problem was not in the spindles, rubber cords, or torque arms. If I had a good line-up on a place that could have fixed the axle for less than I had to pay for replacing it, I would have done that instead, but I still would want some sort of reinforcement. to help prevent the problem from happening again.
Posted: 09 May 2019 at 6:22am | ||
Either flat or diamond will work but the tube is 40% stronger in bending if you keep it flat rather than turning it to the diamond orientation. For the record, the section modulus of a 3 x 3 x 3/16 tube flat is 1.86 in^3 vs 1.32 in^3 for the diamond. I got an overhang of 13.75 inches to the center of the wheels (midpoint between the bearings) from the axle frame mounts when I measured mine. That puts the bending moment on the axle tube at the supports (no reinforcement) at 1750 lbs/1.32*13.75=18.2 ksi (18,200 psi), for a safety factor/g loading of 1.98 assuming standard structural steel with a 36 ksi yield. So the axle is weaker than I was remembering it was from when I last did the calculation. 2g is an inadequate safety margin IMHO. If someone (StephenH?) were starting from scratch and wanted to do something more elaborate than just u-bolting an angle under the axle like I did, I'd suggest a continuous full length tube with Marwayne's brackets at each end and flanges welded to bolt it to both the frame and the axle (replacing the existing riser). Basically it would be a bolt up combination riser and axle "doubler". These would probably sell like hotcakes to a certain segment of rPod owners, but be sure to get one of our resident attorneys to write an ironclad warranty disclaimer for you All that aside, I'm still thinking that some of the failures that are being reported are due to bent spindles, torque arms, or compressed rubber cords which reinforcing the axle tube won't help. We'll see.
Posted: 08 May 2019 at 10:31pm | ||
When I did the stress calculation the existing axle capability was about 2.5-3 g, which is about 4000 to 5000 lbs per side at yield. Any of these fixes ought to take it up to about 3.5-4 g. It needs to be able to take that kind of punishment to survive real world bump loads. I read a couple of vehicle design articles that indicated that even 3g wasn’t really considered adequate. As another example, Normal category aircraft are certified to 3.8 positive g’s with a 50% safety factor on top of that. Good thing we don’t also get negative g loading on rPods or we’d really have problems. Our black tank contents would be dripping off the ceiling. |
Toyanvil
Senior Member Joined: 15 Feb 2019 Location: Bakersfield Online Status: Offline Posts: 157 |
Posted: 08 May 2019 at 9:42pm | ||
I really like that, I tend to over think things. If mine starts moving I will add a center bar like yours, only welded to the risers and turned on diamond like the axle.
Posted: 08 May 2019 at 7:23pm | ||
Posted: 08 May 2019 at 5:05pm | ||
My swag would be about a 50% improvement, similar to my solution and toyanvil's. That is closer to a couple thousand ponds per side
