steel bolts vs stainless steel for attaching axles |
Post Reply | Page 12> |
Happy Tripping
Topic: steel bolts vs stainless steel for attaching axles Posted: 23 May 2019 at 5:28pm |
Does anyone know if there is any information/recommendation out there concerning replacing the regular steel bolts that attach the axles to the frame with non-rusting stainless steel ones??
lostagain
Posted: 23 May 2019 at 6:23pm |
Not all stainless steel is the same. You have to be sure you are getting bolts with adequate tensile strength in addition to corrosion resistance.
Posted: 23 May 2019 at 7:20pm |
+1 In addition to tensile strength, Stainless Steel seems to be a little more subject to galling and seizing of the threads. I've had stainless steel nuts seize on the bolts.
Toyanvil
Senior Member Joined: 15 Feb 2019 Location: Bakersfield Online Status: Offline Posts: 157 |
Posted: 23 May 2019 at 9:54pm |
All Stainless Steel bolts and nuts need lube before assembly. Stainless Steel bolts do not have the tensile strength you need for an axle, use grade 8 steel bolts and paint them with good paint.
Posted: 24 May 2019 at 6:19am |
SS bolts might be strong enough for the application but I agree with Toyanvil. This is not a good place to use them. Grade 8 steel bolts are stronger and won't gall. If you use steel bolts then there won't be a dissimilar metals galvanic corrosion problem between them and the axle and chassis steel brackets. If you use stainless you will be setting yourself up for galvanic corrosion of the brackets because they will be anodic to the stainless steel. I'd much rather just paint the steel bolts, inspect them occasional for corrosion, and replace them if necessary than risk corrosion of the brackets, which would be much harder to repair. |
Posted: 24 May 2019 at 7:27am |
My '48 Buick has regular steel bolts holding the suspension on.. I see no reason to use SS if the grade 8's are going to last 70 years to begin with....
Posted: 24 May 2019 at 8:00am |
Depends where you live. Here on the Outer Banks with a hot, humid, salt spray environment, nothing metal short of gold lasts 70 years. More like 10-15 for steel if you're diligent about flushing with fresh water, painting, and using a water displacement material to fill all exposed cracks and crevices. I spray the bottom of my vehicles with Fluid Film a couple of times a year and that seems to help quite a bit.
lostagain
Posted: 24 May 2019 at 8:45am |
Another thing that puzzles me regarding the use of SS bolts: The brackets are still regular steel and are pretty thin, and are welded to an even thinner trailer frame. Seems to me that the brackets and such would still fail from oxidation and all you're doing is moving the point of failure to a different location, kinda like putting one SS link in a steel chain. I could be wrong, but most steel bridges and such, certainly exposed to the elements, use steel bolts. I should call one of my friends at Iron Workers 377 to check.
Posted: 24 May 2019 at 9:11am |
+1. That was exactly my point. You're creating a dissimilar metals corrosion problem where there wasn't one, and that problem results in the trailer and axle bracket steel now being sacrificial to the SS bolt. Since those are big bolts connecting to relatively thin steel its not good.
Happy Tripping
Posted: 24 May 2019 at 11:48am |
Thanks to all, this is very useful information.
