Dang, that was my favorite axle, too |
Post Reply | Page 12> |
Happy Tripping
Topic: Dang, that was my favorite axle, too Posted: 03 Jun 2019 at 3:04pm |
We live in West Virginia. A couple of days after coming back from a trip to the Gulf of Mexico and in preparation for a trip to the Outer Banks of NC, I was backing up into our driveway at about 1 mph when I heard a sudden sharp scraping sound. Since I have had trouble elsewhere with the rear stabilizer jacks, and since it had stopped, I resumed backing up when it did it again. That was enough for me. I got out to find my axle had broken off and the wheel had damaged the right fender. Although the left side wheel was also cocked, the black tank and outlet on that side was not involved. (Our neighbors don't know how lucky they are.) The axle shop told me initially that a weld had failed but that they couldn't work on it right away. Today the axle shop go it up on their rack and they confirmed that a weld between the frame and riser failed on the right side.
We consider ourselves to be very fortunate that it happened in our driveway. At highway speeds the accident could have been catastrophic, both to us and to other drivers. Of course I informed Forest River immediately. Their initial response was that a bolt that I was responsible for had loosened. It will be interesting to see what their response is now. I am reporting this to the National Highway Safety Traffic Administration (www.nhtsa.gov) as a crash, albeit 'only' a little one. |
"There comes a time in the affairs of a man when he must take the bull by the tail and face the situation" - W.C. Fields
Posted: 03 Jun 2019 at 3:37pm |
Wow. That was a lucky break! Sorry to hear it happened, but glad for the circumstance. Which R-pod and how old?
Posted: 03 Jun 2019 at 5:03pm |
Wow +2.
Posted: 03 Jun 2019 at 6:01pm |
Wow! +3 I'm glad it happened at home. That could have been really bad.
Posted: 03 Jun 2019 at 6:17pm |
I guess that makes one more item on our pre-flight checklist...
Posted: 03 Jun 2019 at 6:51pm |
How do you check a weld that is about to break?
Posted: 03 Jun 2019 at 7:55pm |
Sorry to hear about the weld breaking. At least it happened before you left home. What bolts did FR say were involved if the local shop identified a weld? I guess FR takes the position that all welds and bolts should be subjected to destructive testing as part of the routine maintenance.
marwayne
Posted: 03 Jun 2019 at 8:45pm |
I'm sorry that happened to you, however I'm confused. There is only one weld and that is the bracket on to the axle and if that is the weld that failed yes FR should cover that under warranty. However if the riser was welded to the axle bracket and to the pod frame that is not the way FR installs risers. I have axle risers, there 2 bolts holding the riser to the axle bracket and 2 bolts holding to the pod frame.
podwerkz
Posted: 03 Jun 2019 at 9:52pm |
Wow.....I hate when that happens....
Posted: 04 Jun 2019 at 5:47am |
Sorry about the failure. From the hints you've been giving about what happened is not a surprise.
i suggest that you go to your axle shop and take some detailed photos before all the evidence disappears. Try to get photos of the broken weld, where it was and how the crack propagated. Also it would be good to have them confirm that the riser bolts were indeed tight (it they were) and not lose as apparently FR has already tried to claim. From what you're describing, this failure likely wasn't sudden, (backing up a trailer at 1 mph isn't particularly stressful to the suspension system) so the crack has likely been there for awhile and has propagated along the weld to the point where backing up one final time broke it. That is typical with fatigue cracks in metal joints. If so, there might be corrosion on part of the crack but also a section which is fresh and doesn't show corrosion, so you might be able to tell where the crack started and ended. Since Lippert makes both the axle and the frame of the rPods (at least on mine) either way its probably on them. The risers do increase stress on the frame and on the frame bracket welds because they create a longer moment arm (think lever length) between the wheels and the frame, so that could be a contributing factor. |
