Some sobering video of what NOT to do towing |
Post Reply | Page <12 |
podwerkz
Topic: Some sobering video of what NOT to do towing Posted: 15 Jun 2019 at 10:14am |
Most of that will buff right out.
crankster78
Senior Member Joined: 08 May 2018 Location: Minn Online Status: Offline Posts: 163 |
Posted: 14 Jul 2019 at 7:47am |
Greetings: A couple of days ago, traffic cams picked up a incident in the MN metro area. The SP stopped a TV with about a 25 foot trailer for a violation. The Driver decided to take off. Bad idea! The SP place stop sticks on the roadway, the driver swerved to avoid, lost control, rolled the whole rig. Now, not only wrecking everything he is facing multiple charges. Isn't it fun to know that your sharing the road with folks like this??? Crankster78
Crankster 78 R-179 2015
Colt
Posted: 05 Dec 2019 at 9:37pm |
So, ..... what kicks off the swaying? Once it starts, it looks uncapped and just grows.
John
'16 R-Pod 180 |
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2624 |
Posted: 06 Dec 2019 at 9:09am |
There are many short videos on the net that show how this can happen. This is one of them.
Colt
Posted: 07 Dec 2019 at 1:01pm |
Dang autocorrect! Uncapped = undamped.
Great video! It readily shows how having the CG behind the initial center of rotation becomes so quickly unstable. Seeing makes understanding much easier. |
John
'16 R-Pod 180 |
Posted: 11 Dec 2019 at 6:57am |
Trailer sway is actually a pretty complex dynamics problem. I did a search once and found a couple of papers which concluded that FEA modeling was needed to analyze it properly.
The key though I think I s to be sure your rig is self damping, as there are always going to be random lateral force inputs (sudden maneuvers, air pressure from a passing truck, etc) which can set off sway. To be sure you’re self damped, you can very carefully apply a steering input while you’re running down a straight traffic free stretch of highway. Your rig shouldn’t oscillate more than one cycle before returning to straight and level. If it doesn’t then move weight forward in the trailer and/or remove it from the rear of the trailer. Personally I do this test without sway control, the add sway control for an additional margin of safety. |
