  New Posts New Posts RSS Feed: Gas grill on Rpod won't light
Topic ClosedGas grill on Rpod won't light
Babysaph View Drop Down
Direct Link To This Post Topic: Gas grill on Rpod won't light
    Posted: 03 Jul 2019 at 10:20pm
I just got a new Rpod 189 and the inside dove will light but the outside grille will not light. Any suggestions?
Dr. J.R. Chambers II
podwerkz View Drop Down
Direct Link To This Post Posted: 03 Jul 2019 at 11:17pm
Did you open the valve on the bottom of the outside fitting?
Direct Link To This Post Posted: 06 Jul 2019 at 12:53pm
does the hose that was in the tub in the stove hook to the blue hookup up front? I am new to all of this. LOL. stove inside works. Where does the outside stove get gas
Direct Link To This Post Posted: 11 Jul 2019 at 11:18am
What does the hose look like? What fittings are on it?
What 'blue hookup'? What labels are near it and is it metal or plastic?
If you are referring to the curled blue hose, that should be a water sprayer hose, I assume.
Your outside stove, is it a portable unit or attached to the RV?
You need to provide more info about what you are looking at for us to be of much help...we aint mind readers!
Tongue
mjlrpod View Drop Down
Direct Link To This Post Posted: 11 Jul 2019 at 11:39am
The propane valve outputs low pressure fuel. It is regulated by the pods regulator on the propane tank. If your grill or stove also has a regulator on it, it will not work. I am guessing that is the problem. You need to remove the regulator from the grill/stove, or use an unregulated 20 pound or 1 pound tank to feed it.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
teampitt View Drop Down
Direct Link To This Post Posted: 11 Jul 2019 at 4:50pm
Are you referencing an outdoor GRILL or the new outdoor STOVE?
The blue hose that was in the sink tub of the outdoor kitchen in the new rpod is a WATER hose for the high pressure port right next to the outdoor kitchen. Don't try to hook that up to the propane.
Direct Link To This Post Posted: 12 Jul 2019 at 9:17am
Any update on what is going on??? It's nice to know if you actually get helped, and it can help someone else in the future if you share what was/is going on.
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
