  New Posts New Posts RSS Feed: R-Dome (Dometic Cabana) Flex Pole
Topic ClosedR-Dome (Dometic Cabana) Flex Pole
lhamblin View Drop Down
Direct Link To This Post Topic: R-Dome (Dometic Cabana) Flex Pole
    Posted: 06 Jul 2019 at 11:31am
We went to setup our R-Dome (Dometic Cabana) for the very firts time only to discover that the Flex Pole that goes through the R-Dome has a broken pin that connects the flex rod in the middle of the rod.  Does anyone know where to acquire a new flex pole for the R-Dome.  The Flex Pole measures 22.5 feet in length.
LHamblin
Pod People View Drop Down
Direct Link To This Post Posted: 07 Jul 2019 at 8:15am
You can make a repair using a piece of tubular aluminium that is the correct size.  The new piece will fit over the r dome pole and created a solid joint.  there are several tent pole repair kits available on the internet
https://www.google.com/search?client=firefox-b-1-d&q=aluminium+tent+pole+repair+kit
we have done this in the past with standard tent poles and it works fine.
Vann
Vann & Laura 2015 RPod 179
