light in frig |
Post Reply | Page 12> |
Guests
Guest Group |
Topic: light in frig Posted: 25 Jun 2010 at 1:03am |
Has anyone had a problem with the led light in the frig? It was working then it just quit.
Posted: 25 Jun 2010 at 7:04am |
No problem with mine. Since LEDs don't burn out (at least not for years) it must be a connection problem. I would start with finding the switch and see if you can pull it out and look at the wires.
paul
Newbie Joined: 18 Jul 2010 Location: canada Online Status: Offline Posts: 7 |
Posted: 19 Jul 2010 at 8:33am |
Hello,
My fridge light did not work, I did not even realize that there was one till one day it came on accidentally. Then it went off and it never comes on when I open the fridge. An odd thing I discovered was the fact that when I remove the fuse for the fridge and subsequently put it back , I hear a clicking sound and presto, the light is on. Then it goes out again and can only be activated by removing and reinserting the fuse. There does not appear to be an on/off switch in the door to activate the light, since I took the locking system apart and it only contains the led block. Anyone else experience this puzzling situation? Apart from misjudging the effect of low branches , I have been very happy with this RV. Paul |
Guests
Guest Group |
Posted: 19 Jul 2010 at 12:12pm |
We also have this problem. Had it fixed and it is out again.
HuronSailor
Posted: 19 Jul 2010 at 5:31pm |
We noticed last trip that our fridge light seems to have a mind of its own too. I forgot all about it until I read your post.
The only reference to the light in the owner's manual says that after the door's been open for 2 minutes, the light will go out.
Posted: 19 Jul 2010 at 10:52pm |
I noticed the 2-minute timer on our trip last week, too.
paul
Posted: 24 Jul 2010 at 7:20am |
Thanks guys, that is good to know. It tells me that most likely the circuit board is defective and I'll contact the manufacturer for a replacement. Paul |
paul
Posted: 27 Jul 2010 at 12:57pm |
Hi Plodders,
Contacted manufacturer and get directed to dealer, but he is too far away, so I am trying to locate the switch in the fridge door that would trigger the leds. Does anybody know where ? A finicky Canadian |
HuronSailor
Posted: 27 Jul 2010 at 3:08pm |
I just went to check mine, couldn't find a switch. The manual says the LED's are "sensor controlled."
BTW, my fridge light quit working altogether this past weekend.
paul
Posted: 27 Jul 2010 at 3:50pm |
Thanks Huron sailer,
I will take the thing apart and see, can't stand these little mysteries. Will let you know if I find something, Paul |
