Measured wattage of 'pod appliances |
Post Reply | Page 123> |
Topic: Measured wattage of 'pod appliances Posted: 11 Feb 2021 at 2:33pm |
IIRC the a/c fan uses about 3 amps so around 350 watts. No problem running it from s 2kw generator. But all it will do is recirculate warm air in the trailer. The fantastic fan will draw in outside air and uses much less power, and runs on 12v so you don’t need to run the generator all the time.
GlueGuy
Posted: 11 Feb 2021 at 1:29pm |
The fan alone should not be a big draw. Probably a fraction of running the compressor. It will still require AC (AKA shore power), as the fan is an AC powered fan (as opposed to battery power).
BoardinGordon
Newbie Joined: 11 Aug 2020 Location: CO Online Status: Offline Posts: 5 |
Posted: 11 Feb 2021 at 11:16am |
This is incredibly helpful - thank you.
Does running the overhead AC unit in fan mode instead of AC mode require as much pull? I am wondering if my 2000 w generator can run the fan without AC.
Posted: 25 Oct 2020 at 5:42pm |
Probably won't start the a/c but you could try and then add an easystart if it didn't. Should run it OK once started, as long as everything else is off. If you get it let us know what happens. At this point it will be next year before you can do a definitive test, the startup current gets higher as the ambient temp increases.
Also consider getting a propane generator, since you already have a propane tank it will save you some weight and stinky smells in the SUV.
pedwards2932
Senior Member Joined: 21 Sep 2020 Online Status: Offline Posts: 337 |
Posted: 25 Oct 2020 at 12:58pm |
I saw this at Home Depot:
Has 2500 peak and 1850 running weighs in at 39 lbs. Not sure if the extra peak is enough but it does have 20 amp plugins. |
KMcCMedia
Newbie Joined: 23 Sep 2017 Location: Massachusetts Online Status: Offline Posts: 1 |
Posted: 25 Oct 2020 at 12:32pm |
This post is old, but I'm grateful the poster took the time to provide useful info! Thanks!
Posted: 02 Oct 2014 at 1:54pm |
And then there are pods like ours.. Mine has a hard start and will start on a Honda 2000 if we have the fan already running on low.
Budward
Senior Member Joined: 21 Apr 2014 Location: SC/NC Online Status: Offline Posts: 438 |
Posted: 30 Sep 2014 at 1:11pm |
Honestly I could tell no difference in the hard start cap vs without. Wish I had a current reading chart recorder to see what the difference really is....
2014 179
Towed by a 2015 Ford Transit Diesel Supervised by a German/Aussie mix and a Labradoodle! |
Posted: 30 Sep 2014 at 8:00am |
I never had a problem with mine, and no hard-start capacitor. I would get a slight dip in the fan's rpm when the compressor started, that was it.
Budward
Posted: 29 Sep 2014 at 9:12pm |
It won't. I have the 2400iSHC and a Supco hard start cap. What I do plan to install when I get time, already bought the parts, is a solid state timer relay that cuts off the fan when the A/C is commanded to start, then 10 seconds or so later brings the circulation fan back online. That will shed 200 or so watts from the generator to ease compressor starting. I also unplug the microwave when running on generator for A/C- otherwise it beeps every time the A/C starts as it sags voltage enough to make it "think" it has completely lost power then beeps when the compressor has lost its start up load and voltage is back to normal.. |
2014 179
