R179 kitchen sink fell out |
Post Reply | Page 12> |
garyd
Newbie Joined: 09 Oct 2017 Location: broomfield co Online Status: Offline Posts: 38 |
Post Options
Quote Reply
Topic: R179 kitchen sink fell out Posted: 25 Aug 2019 at 3:40pm |
The sink on my rpod179 fell through the countertop cutws! I want to repair out. It was only held in with 4 screws.
I want to put in proper sink clips but I didn't know how to get access to bottom of sink? Do I need to disassemble the drawer rails and if so how to do this. Has anyone repaired the same issue. |
gary
GlueGuy
Post Options Quote Reply Posted: 25 Aug 2019 at 4:22pm |
Several people have had this happen. Usually, it's because the edge wasn't properly sealed. You can re-seal the edge with epoxy & then re-attach the sink, or you can install a sink that hangs from a lip, and is sealed around the edge.
I don't see a comfortable way to do this without taking out the drawers. |
garyd
Post Options Quote Reply Posted: 25 Aug 2019 at 8:33pm |
Thanks for your help. It just seems that I shouldn't have to spend so much time rebuilding poor design and quality
gary
Post Options Quote Reply Posted: 25 Aug 2019 at 9:35pm |
I saw this once. The owner had the undermount sink and had carried some items, including a jug of water IIRC in the sink while traveling. I installed a top-mount sink in ours so this is not a concern for me. The bottom line would be that those with undermount sinks should not carry items in them while traveling or should reinforce the sink before doing so.
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Post Options Quote Reply Posted: 26 Aug 2019 at 8:29am |
I do not have mine here to investigate, but I figure you have a few things to take apart to get at it.
Hopefully the inserts are still in the top and you just require sealing and screwing back on. I say hopefully, due to all else that has come apart in mine and I've re-done. If you have the composite top, silicone or plumbers putty please. Hard drying adhesives can add to cracking you top. If the inserts came out.. New brass ones and drill according to the spec's for them. Tapped in correctly, they do not need any adhesives. The easiest fix is what StephenH said: Drop-in replacement. |
Post Options Quote Reply Posted: 26 Aug 2019 at 9:32am |
Earlier Pods came with top mount sinks.. I wondered if the change to under mounts would work out.. thankfully, for the most part it has, but we have had a few owners with it failing..
I agree that going with a top mount replacement is the best and most secure "fix".. but it does take away from the more modern look of the undermount.. The drawers should just pull out, and the space will be clear. |
Post Options Quote Reply Posted: 26 Aug 2019 at 10:00am |
The one thing the undermount gives that a top-mount lacks is the ability to put an insert in for a flat work surface that includes the area of the sink. A cover can be put over a top-mount sink, but it won't be flat with the countertop. On the 179, it isn't a big deal as there is a lot of countertop to work with. On some of the other models, it is a bigger deal since counter space is very limited. Our 179 came with the tiny plastic sink. One of my early mods was to replace it with a larger stainless steel sink and at the same time, replace the cheap faucet with a better one. It was something that has worked out very well for us and my wife likes it which is the most important part.
garyd
Post Options Quote Reply Posted: 27 Aug 2019 at 10:30am |
thanks to you all. I removed the sink and found out it was a drop in type sink? anyway I top mounted it and glued it in place with 3m 4500 adhesive. THis shoud be waterproof and secure for the life of the trailer.
gary
Post Options Quote Reply Posted: 27 Aug 2019 at 11:01am |
Even the undermount sinks have a rim. The issue is that it isn't usually very attractive visually since it is meant to be mounted on the bottom of the counter. There is nothing preventing one (as you showed) from dropping it in from the top and gluing it in place though. It certainly is stronger that way.
Post Options Quote Reply Posted: 27 Aug 2019 at 11:48am |
I like your solution.
Sometimes the older designs are better. Undermount sinks are simply not as structurally sound or water resistant as drop in sinks. French door refrigerators with their complex sealing system are just not as robust as side by side fridges. Personally, I'm happy to adopt new things if they are actually better (like LCD TVs vs CRT TVs) but if not, I'll stick with what works as long it is still available. Just my $0.02.
