  New Posts New Posts RSS Feed: Cell phone
Topic ClosedCell phone
Olddawgsrule View Drop Down
Direct Link To This Post Topic: Cell phone
    Posted: 04 Sep 2019 at 7:41am
I run a generic system I put together with a Yagi (directional antenna) and a over stocked booster. I wanted to try before investing into the newer versions.
I agree with offgrid, it will only 'boost' what is there. For me I never saw 3g go to 4g, just a stronger 3g. May be my generic unit..
I assume most of the new antennas are already setup for the wide band of frequencies cell providers work on. My Yagi, I had to be careful I bought that covered the range (also wanted WIFI).
I found my Yagi to be very finicky for aiming, though typically stronger receivers, that issue along would make 'my' decision for omni directional. Again, maybe the newer ones are much better. LOL, I lost my Wifi when a big ol' Class A parked between me and the transmitter.
Do they work, yes. How well, just like the normal signal, depends where you are and what you can grab.
Just my experience with mine.
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 04 Sep 2019 at 12:41am
I do. I use a Wilson weboost slim.
I also have an additional directional antenna on an extension pole I clamp to slide edge and point at the cell tower while camped in a weak signal area. You also would need a low impedance coax cable to run from the antenna and the right connector adaptor to the weboost. All from Wilson except the extension pole.
Works pretty well but not everywhere, there has to be a signal to boost.
1016 View Drop Down
Direct Link To This Post Posted: 03 Sep 2019 at 9:11pm
Does anyone use a cell phone booster and if so which ones do you use
