Micro-Air easy start |
Post Reply | Page 123 6> |
Topic: Micro-Air easy start Posted: 28 Aug 2020 at 10:41am |
It is high time for modern technology to be incorporated. The issue is to make it durable enough to survive bouncing around. Most mini-splits are not going to be involved in a rolling earthquake.
podwerkz
Posted: 28 Aug 2020 at 9:55am |
Makes me wanna buy one....just cuz....
Posted: 28 Aug 2020 at 9:14am |
The easystarr is a good device but it is just a patch covering up the real problem.
Modern inverter based variable speed compressor systems have very low startup current requirements. So new high SEER mini splits and central air conditioners do this already. What we need is for the RV a/c manufacturers to get out of the stone age and implement some modern high efficiency technology. Their stuff is still pretty much 1960's tech. Its not like the new systems are more expensive either, you can buy a 12kbtu/hr high efficiency minisplit for less than a Dometic Penguin. The RV a/c market is ripe for the entry of some disruptive technology I think.
Posted: 28 Aug 2020 at 8:42am |
Thanks for the report. I installed one and have been very happy with it as well. I think the manufacturers should incorporate this technology in the units when they are built. If it were done at that time, the price per unit would likely not be much more, but the ability to run on generators would be worth the difference.
neufox47
Newbie Joined: 02 Aug 2020 Location: California Online Status: Offline Posts: 6 |
Posted: 27 Aug 2020 at 11:36pm |
Generator and soft start worked well up at 6,000 + feet in 90 plus temps in full sun. The baby slept well during his naps!
neufox47
Posted: 10 Aug 2020 at 12:04pm |
We installed the soft start in about 30 minutes. Was pretty easy, just had to follow the directions / diagrams. Start is far softer now, we’ll see how it does at 4,500’ when it is 90 plus this weekend.
Posted: 08 Aug 2020 at 9:33am |
Well I guess we have to chalk this one up to brand rental then. Westinghouse was once long ago a company and brand with a great reputation, but that company no longer exists. Now there is am entity called Westinghouse Licensing that grants rights to use that brand to all sorts of companies for all kinds of products of varying quality and performance levels. Oh well....
Chopperbob
Newbie Joined: 04 Jul 2020 Location: Delaware(DE) Online Status: Offline Posts: 8 |
Posted: 08 Aug 2020 at 8:48am |
I just had one installed at Micro-Air in NJ. Nice folks. On a really hot and muggy day a Honda 2000 generator started the A/C and ran it in eco-mode, no problem.
Marveling at the Design!
neufox47
Posted: 07 Aug 2020 at 10:48am |
Yea, it is / was out of efficiency mode.
Posted: 06 Aug 2020 at 5:56am |
Thanks for the clear explanation. That is what I thought was happening but its good to be sure. The problem is that once the condenser and evaporator sides of the a/c build up a temp differential from running they also build up a refrigerant pressure differential. Then the compressor has to overcome that pressure differential to start the second (and following) times. The easystart will solve that problem for you, I'm sure. It brings the starting current load on the compressor way down. Before you install the easystart one question though. Have you tried taking that generator out of "efficiency mode" and seeing if it will start the compressor that way? As you say its crazy that a genny that size won't start a 13000 btu a/c. Maybe the designers have gone overboard trying to save fuel by idling the generator too low in efficiency mode so it doesn't have enough energy stored in its rotating mass to get through a/c startup. Try it and see if you haven't, that might solve your problem without needing the easystart.
