  New Posts New Posts RSS Feed: Heater
Topic ClosedHeater
Larry-D View Drop Down
Direct Link To This Post Topic: Heater
    Posted: 19 Oct 2019 at 11:03am
And the Vornado is quiet.
Pod People View Drop Down
Direct Link To This Post Posted: 17 Oct 2019 at 5:40pm
agreed-if you are plugged in, use a small electric cube heater.  they are available at all of the home improvement and big box stores for under $30.  Make sure thaey have a tip-proof shut off and a thermostat of some type. The tip proof will automatically turn it off if it is turned over.  The thermostat will help regulate the heat-turning it on and off as needed for a set point.  Usually the set points are not temperatures, but 1-2-3, etc. After working with it, you will know what number is best depending on exterior temp.
Vann
Vann & Laura 2015 RPod 179
crw8sr View Drop Down
Direct Link To This Post Posted: 16 Oct 2019 at 6:26pm
We use a Vornado.  It's a heater and a fan.  Keeps us toasty.
Chuck & Lyn
Izzy, Morkie. RIP
Zoe Joy & Gracie, Yorkie
2018 R Pod 190
2019 Traverse
Jarhead View Drop Down
Direct Link To This Post Posted: 15 Oct 2019 at 9:47pm
Thank u👍🏻
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 15 Oct 2019 at 9:20pm
No, but if you have 110 a better option might be a small electric heater anyway.  You're probably paying for the electricity whether you use it or not and an electric heater is a lot quieter than the rpod furnace.
TT
FJ Cruiser
Direct Link To This Post Posted: 15 Oct 2019 at 9:04pm
Ok but won’t work just plugged into a 110 with propane and battery turned off?
seafans View Drop Down
Direct Link To This Post Posted: 15 Oct 2019 at 8:52pm
The heater works on 12 volts DC.  Should work anytime the propane is turned on and a charged battery.
Direct Link To This Post Posted: 15 Oct 2019 at 8:43pm
Does the heater only work when connected to 240? Mine only working with propane?
