  New Posts New Posts RSS Feed: Gulf Stream Vista
Topic ClosedGulf Stream Vista
Direct Link To This Post Topic: Gulf Stream Vista
    Posted: 31 Oct 2019 at 7:03pm
    Having our camper looked at to see if the front tongue should be strengthened because it bows some when fully loaded. We have the heaviest Vista model for the their 23 foot models and have noticed the 2020 models the front tongues are built with a stronger frame. We are taking it to Tropic Trailer in Fort Myers Florida while there they will repack bearings and inspect frame and make their recommendation if it should be strengthened or not. I just feel unsafe the tongue may break while being towed I never had a camper where the tongue would bow like the Vista does. Has anyone else had a camper or trailer that the front tongue would bend without it being a problem? I am trusting the engineers at Gulf Stream know what they are doing but wandering why the 2020 models now are built with a stronger frame for the tongue.
2014 Ram 1500 Quad cab
Direct Link To This Post Posted: 31 Oct 2019 at 8:42pm
You can't be the first one to notice that it bows. If a tongue bows (and they all do), the amount should be invisible to the unaided eye.
Direct Link To This Post Posted: 01 Nov 2019 at 8:26am
Is there a a Vista or GS user group of any kind where you have e better chance of contacting owners of that particular configuration?
Manufacturers do address issues as model years go forward.. reinforcing a frame is a pretty standard thing.
I agree all tongues deflect, AND it shouldn't be obvious.
Direct Link To This Post Posted: 01 Nov 2019 at 8:58am
Steel is a very flexible material so the frame will deflect a lot (probably at few inches) before it gets near a yield failure (failure being defined as the point at which it doesn't return to its original shape when the load is removed). So you might see what looks like a lot of deflection but in reality it might not be an issue for the frame other than visually.  A problem that could crop up though is damage to the trailer box walls and floor which are too stiff to flex along with the frame.
Reinforcing the trailer tongue/frame won't hurt anything but it will add a bit of weight and reduce ground clearance if you add steel under the existing frame rails. If you do add reinforcement I suggest carrying it back under the box a ways rather than stopping where the tongue and frame meet, when I looked at frame loads on rPods the max load was a couple of feet behind the front of the trailer box, not on the tongue itself.
You could try running a string line along the tongue and frame and see if you can measure the deflection when the trailer is loaded vs when its unloaded and de-watered. Also see if you can find where the deflection is max, it will probably be a bit behind the front of the trailer box.
Direct Link To This Post Posted: 01 Nov 2019 at 4:01pm
I am on the Gulf Stream forum and there is about one post every two weeks from a owner of a Vista Cruiser maybe not even that often. There is a facebook forum for the Vintage Cruiser but I am not on facebook. The Gulf Stream Visa or Vista has never been a very popular camper not sure why we are very happy with ours. As far as seeing the bend in the frame it is obvious my guess if you were to take a strait edge from the front of the tongue to where it joins the frame under the camper to the front hitch there would be about a half inch gap or more in the center. When we load the camper for our trip to Florida I will measure with a strait edge to know the gap in the center as to how much it is bending.
Direct Link To This Post Posted: 01 Nov 2019 at 4:15pm
Thank you, Your explanation makes me feel better perhaps the engineers at Gulf Stream do know what they are doing. I may still ask to have it looked at or least get a opinion at Tropic Trailer when I have It there to have bearings repacked.
Direct Link To This Post Posted: 01 Nov 2019 at 4:18pm
Try to take a string line back well behind the point where the tongue attaches to the frame if you can, it is fairly likely that the deflection starts farther back than that point.
Direct Link To This Post Posted: 02 Nov 2019 at 7:11am
Yeah, I have wondered why they aren't more popular, we really like the Vintage Cruiser line. And back when we were first looking, the Visa line had a couple very nice (to us) floor plans.
I know many people think/feel Facebook is evil.. But like anything, it's all in how you use it. It might be worth it to join, and join that one group, just to see how much action there is there. It doesn't cost anything, and you can just never go back, and remove your profile, if it isn't helpful.
Taking some measurements would for sure be a good idea, even if only for future reference of changes.
Direct Link To This Post Posted: 02 Nov 2019 at 8:04am
Ummm, its not about how you use Facebook, its about how they use YOUR data. YOU are the product they are selling, and your control over how they use your information is limited.  You can exercise some control though if you take the time when you set up your account. Personally the benefits aren't worth it to me.
Direct Link To This Post Posted: 02 Nov 2019 at 10:40am
You literally can make up a name. I used a throw away e-mail address. They don't know anything you don't post.
