Jarhead
Topic: Winterizing Posted: 08 Nov 2019 at 1:37pm |
I switched the water pump to pull from the jug of antifreeze into the lines . Is it normal for the pump to stop? Does that mean the lines are full of antifreeze? There was still about half a gallon left in my second jug when it stopped?
texman
Posted: 08 Nov 2019 at 2:01pm |
do you have your sink and bathroom valves open while pump is on?
Posted: 08 Nov 2019 at 2:05pm |
If nothing is open or on, the pump when it reaches pressure will turn off automatically whether there is water or antifreeze in the lines.
Olddawgsrule
Posted: 08 Nov 2019 at 2:13pm |
Originally posted by Jarhead
I switched the water pump to pull from the jug of antifreeze into the lines . Is it normal for the pump to stop? Does that mean the lines are full of antifreeze? There was still about half a gallon left in my second jug when it stopped? |
Kinda curious how you changed the valves, if you're halfway into the second jug.. I was very quick on the trigger this time and filled all my lines with 1 gallon...
My first thought is you didn't shut off the hot water tank value and took that much to fill it before pressure built up.
Posted: 08 Nov 2019 at 4:33pm |
If he had the WH valves open it would have taken more than two jugs to fill.
Olddawgsrule
Posted: 08 Nov 2019 at 4:35pm |
Originally posted by mcarter
If he had the WH valves open it would have taken more than two jugs to fill. |
If empty... Thus the question.. Shall we wait to hear from the OP?
DavMar
Posted: 09 Nov 2019 at 5:47pm |
Why even bother using RV antifreeze unless you live in the frozen north country, except in the traps and a little in the toilet, and just use compressed air. I know its just to easy!
wonder dog.
2017 Rpod 180
2016 Toyota Tacoma SR5 4x4
Lexington, NC
Olddawgsrule
Posted: 10 Nov 2019 at 7:32am |
I used to do that in my other trailers over the years. I found it to be a PITA compared to using anti-freeze. I can do the anti-freeze now with just a gallon and in less than a half hour (setup & clean-up).
To each their own.
riotkayak284
Posted: 10 Nov 2019 at 7:51am |
Yep, Anitfreeze is super easy and takes little to no time.... and it adds a layer of insurance...
Jarhead
Posted: 10 Nov 2019 at 12:54pm |
I had the outside shower open so it used up extra antifreeze. Pain in the ass, Next time I’m just using air.
