Electric - Event Date: 18 Nov 2019 - 28 Nov 2019 |
Post Reply | Page 12> |
Calendar Event: Electric Posted: 21 Nov 2019 at 7:44pm |
The Hughes Autoformer showed up today. It should help to avoid some power problems. It will get tested next week.
GlueGuy
Senior Member Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2628 |
Posted: 19 Nov 2019 at 9:47am |
CharlieM
Posted: 19 Nov 2019 at 8:55am |
If you have the full function SurgeGaurd by TRC it will detect and protect against low or high voltages as well as miss-wired and and open lines. The cheaper surge protectors will not. I have had my SurgeGuard interrupt power when the voltage dropped to 102V due to poor campground equipment.
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 19 Nov 2019 at 7:50am |
My Surge Guard has shown faults at the pedestal a couple times so far, both times reverse polarity. Curious if it would have shown 'low power' as no power or some other fault..
I do consider the Surge Protector another worth while item to have.
Posted: 19 Nov 2019 at 6:15am |
WFCO is the manufacturer of the battery charger in the trailer, which is located in the bottom of the electrical panel. Even if your battery is completely dead it should be able to provide enough current to bring the slide in, assuming it is operating. So if the slide starts in for a few seconds and then stops you have a dead battery and its not getting charged. The WFCO chargers are not the most reliable things in the world. I would start by checking all the fuses and breakers and then connecting to a known good 120Vac source (to avoid the possible low voltage issue StephenH raises) and see if that brings your battery voltage up. Although its a good idea to have one, you can tell even without a DVM because the lights, fans, etc will start to get brighter when you turn on the charger. You can also use a separate portable battery charger connected directly to the battery terminals if you have one handy. Your battery has been completely discharged, which is not good for them, they can only tolerate that a limited number of times. After you get your charging system fixed and the battery fully recharged you might find that it won't hold a charge, so you might need a new battery too at some point. A DVM can show a low ac voltage condition under load just like an analog meter, all you have to do is connect it while the loads are turned on. That can be done using one of the trailer electrical outlets. |
Blue Ridge
Newbie Joined: 25 Sep 2019 Location: NOVA Online Status: Offline Posts: 7 |
Posted: 18 Nov 2019 at 4:21pm |
FYI
A digital volt meter may or may not show a low voltage condition where an analog meter would show it. I have tested circuits that showed the correct voltage but when connected to a load dropped low because the circuit could not supply enough amperage to run the load. Typically you would see this caused by a loose connection in a damp location (ie: power pole in camp ground).
Posted: 18 Nov 2019 at 4:05pm |
Mr. Coffee is pure resistance heat. It is not as sensitive to low voltage as things that have electronics and motors. I suspect that the voltage at the post was low, essentially giving you brownout conditions. A digital voltmeter is definitely a good investment as is a good circuit analyzer that plugs in to the post (or hard wires, your preference). We have a Camco one that is basic, but did spot a faulty post at one campground where we changed sites. I am glad I had not done all the setup first. There is a plug-in voltage conditioner that can boost low voltage, but it normally costs an arm and a leg and a firstborn child. However, Amazon has the Hughes Autoformer right now at $339.70, which is a bargain for what it does. I just ordered one since I have been waiting for them to come down in price. That is over $80 less than I have seen it selling for before now. |
GlueGuy
Posted: 18 Nov 2019 at 2:50pm |
Yup DVM is Digital Volt-Multimeter (or just Meter), but they typically measure volts, amps, ohms, and sometimes a few other things, so I use "Multi"
poston
podders Helping podders - pHp Joined: 28 Mar 2018 Location: Nevada Online Status: Offline Posts: 195 |
Posted: 18 Nov 2019 at 2:25pm |
Digital Voltmeter? |
-- Jim Virginia City, Nevada 2016 R-pod 180 2015 Nissan Xterra Pro-4X |
lostagain
Posted: 18 Nov 2019 at 12:49pm |
Hey Glue Guy, what's a DVM? What came to mind was Doctor of Veterinary Medicine but I don't think that's what you meant.
