  New Posts New Posts RSS Feed: Fresh water tank and freezing weather
Topic ClosedFresh water tank and freezing weather - Event Date: 07 Dec 2019
GlueGuy View Drop Down
Direct Link To This Post Calendar Event: Fresh water tank and freezing weather
    Posted: 09 Dec 2019 at 6:53pm
And if you had shore power, you would probably want to use 120VAC to cut down on the current required.
texman View Drop Down
Direct Link To This Post Posted: 10 Dec 2019 at 9:10am
I insulated my fresh water tank and installed a recirculating water system for freezing weathe.  check out my mods from my signature link if you are interested.
TexMan 2015 182g
2018 Sequoia
TexManMods
Direct Link To This Post Posted: 11 Dec 2019 at 6:22am
+1 on TexMan’s mods. If you want to boondock in moderately cold weather in an rpod and want your fresh water system to work that is the way to go. The electric heaters use far too much energy. The recirculating system uses the propane water heater so carry an extra cylinder and you should be ok.
The gray and black tanks will still be subject to freezing so carry some RV antifreeze for that.
If you are expecting prolonged really cold weather, then keep it winterized. There are true 4 season trailers for that kind of use if you have the $$$.
