Heater placement - Event Date: 13 Dec 2019 |
Post Reply | Page <123> |
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6283 |
Calendar Event: Heater placement Posted: 13 Dec 2019 at 9:21pm |
With our 179, I use a battery operated fan placed at the side of the opening opposite the heater to pull the hot air from under the bed and shoot it out into the larger cabin space. The side closer to the heater is left open for cold air return. This works quite well when we dry camp and are using the propane heater. If we have shore power, I use a small ceramic block heater. Either method gets the job done.
geewizard
Senior Member Joined: 16 Apr 2017 Location: Spokane Online Status: Offline Posts: 347 |
Posted: 14 Dec 2019 at 6:50am |
+1 to everything above. We use the Wave 3 heater in our RPod and truck camper and are quite happy with it. You can search for my posts and see how I installed propane lines with quick disconnects and shutoff valves.
ToolmanJohn
Posted: 14 Dec 2019 at 7:27am |
I used a Mr Heater when I had the Pod. Same furnace under bed layout. Window furthest from the bed cracked a bit, plus the bathroom vent slightly open.
The Mr Heater only has two heat settings, low and high. The Mr Heater LOW setting was still a lot of heat, and the one pound bottles would only last about 3 hours on lowest heat setting. So it was somewhat of an annoyance, knowing it was expensive heat, and wasted heat through the vent. But I never let it get colder than 55°F when sleeping in the Pod. I had two 12 volt Marine/RV batteries, and I could use the furnace if I wanted too for along weekend when cold out, but I actually hated the noise from the furnace directly under the bed, every time it cycles it would wake me. That's why I bought the Mr Heater. Never got around to making a propane connector from the 20 pound tank though, which was my plan for the Mr Heater. My new trailer has a furnace further away, multiple heat ducts, and is significantly quieter.
Posted: 14 Dec 2019 at 8:32am |
Many owners have built a deflector to move the heat out into the living space a little better.
Rpods are small spaces, the heater is a little bigger then a microwave, look around, see where else it could go.. nowhere convenient. They end up where they end up.. because that's where they fit. The heater draws it's combustion air from outside the camper, AND exhausts the byproducts outside. CO is not a danger if everything is running right. We recommend a small bit of cross ventilation in cold temps because of moisture build up and "sweating" that is common in all small spaces when there is a large temperature difference between inside and outside.
Buffalohunter
Groupie Joined: 12 Oct 2019 Location: Bellingham, Wa Online Status: Offline Posts: 57 |
Posted: 14 Dec 2019 at 9:03am |
Thanks for all the good info...my CO and smoke detectors work just fine. The heater does as well that’s why off-road I crank the heater up to 73 so I over heat the compartment whereby convection takes over and some of that warm air spills out into the living space. So bottom line leave the heater in place, maybe when dry camping try another electric heater but most importantly construct some kind of a metal smooth wall diverter. Good call not to go with plastic...don’t need nothing melting on me. Just trying to understand and customize my 189 to make it more comfortable eliminating the cold toes and other unforeseen problem areas. This is such a great site with a wealth of information...thanks mucho.
Posted: 14 Dec 2019 at 9:37am |
That's true in so far as CO is concerned. My original comment about cracking a window and the ceiling vent was in regard to humidity. If you don't mind waking up with water running down your windows and wall, you're right. TT
FJ Cruiser |
Senior Member Joined: 06 Sep 2016 Location: Quaker Hill, CT Online Status: Offline Posts: 2583 |
Posted: 14 Dec 2019 at 10:30am |
Humidity? what humidity? We don't have no humidity out here in NV.
Posted: 14 Dec 2019 at 11:48am |
Well, maybe not, but two people can exhale and/or perspire a surprising amount of moisture overnight. TT
FJ Cruiser |
geewizard
Posted: 14 Dec 2019 at 1:16pm |
http://www.rpod-owners.com/forum_posts.asp?TID=13022&KW=cake+pan&PID=125499&title=rpod-177-furnace-deflector#125499
Posted: 14 Dec 2019 at 2:13pm |
We have dry humor in NV.
