RPod with Solar Option questions |
Post Reply | Page 12> |
Topic: RPod with Solar Option questions Posted: 04 Feb 2020 at 11:07am |
I think you are overthinking this, understandable because the charger manufacturers’ product literature doesn’t use the same terminology and is written by marketing types to try to differentiate their products rather than explain how they all do pretty much the same things.
The difference in how you charge Li vs Pb acid batteries is that you need to drop down to a “float” mode at about 13.6v to maintain full charge on a PbA battery. If you leave it charging at 14.4v it will consume too much water. Li batteries are much simpler to charge than PbA’s. The float charge mode is unnecessary for the Li battery, it’s fine to take it on up to 14.4V and leave it there, in fact it results in an undercharged battery if you don’t. So, if you use a charger that drops from 14.4v to 13.6 you are leaving some of that expensive Li capacity on the table. |
Pod_Geek
Senior Member Joined: 04 Dec 2019 Location: Colorado Online Status: Offline Posts: 260 |
Posted: 04 Feb 2020 at 9:02am |
So I did a little research this morning after seeing your post and found this post from last July: _________________________________________________________________ My understanding (as a self-admitted amateur in this field) is that using a lithium battery with a standard RV converter or lead acid charger (multi stage included) will give you the advantage of the greater depth of discharge available with the lithium battery but you sacrifice the higher capacity of the lithium battery because for a full charge it requires higher voltage that the lead acid chargers will usually provide. So yes, it will work. But will it work "perfectly well" is subjective.
But since I am not an expert in the field, I will quote the manufacturer of what has to be the most common brand of converter / charger in RVs... Progressive Dynamics:
http://www.fiberglassrv.com/forums/f95/need-advice-on-replacing-lead-battery-to-agm-or-lithium-89668.html ______________________________________________________________ More definitive advice from PD is probably needed here as to the Charge Wizard Boost Mode of the 4135 series power centers and Li-ion batteries. |
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L |
GCRicker
Newbie Joined: 22 May 2018 Location: New Hampshire Online Status: Offline Posts: 32 |
Posted: 04 Feb 2020 at 7:38am |
I heard back from Progressive Dynamics about the replacement converter for the WF-8735 that will charge lithium...
"We have the PD4135KW2BV power center which replaces the WF-8735. This model includes a manual Charge Wizard control button on the DC distribution board. Activating "Boost" mode will allow you to fully charge your lithium battery. This is a 35 amp charger and will allow you to charge your battery in about 3 hours." |
Posted: 03 Feb 2020 at 3:10pm |
Unfortunately, it does not look like there is an upgrade for the 87xx series power center. I have the 8955 in mine and was able to swap out the WFCO 8955 MBA for a WFCO 8950L2 MBA (L for Lithium). You would likely need to remove the 8735 Power Center and install the WF-8950L2PEC Power Center if the dimensions allow. I don't know if Progressive Dynamics make something that could replace just the converter section. If so, it would likely be a floor-mounted unit instead of mounting in place of the existing converter section (if that is even removable).
Pod_Geek
Posted: 03 Feb 2020 at 2:18pm |
I was recently investigating this as well and found this, which is consistent with what you've stated: Q: WFCO WF-8735P Power Center and Go Power GP-PWM-10-SQ solar controller. Compatible? Thanks. A: The WFCO units only seem to put out around 13.6 volts when our lithium batteries are installed. Although this will put some charge into our batteries, its will be no where near the rated 35 amps and effectively turns the unit into a trickle charger. Because of this you may never see the batteries get to full and you wont be able to take advantage of the passive balancing effect of our bms that starts at just over 14 volts. We would recommend upgrading to a lithium version of converter. The Go Power charge controllers usually work well in the AGM setting if a lithium mode is not available. battlebornbatteries.com/charger-compatibility-table/ I too am interested in knowing the answer to your question. Note that the solar controller does have a Li-ion setting (at least mine does) and will charge the battery based on Battleborn's comment...just not nearly as quickly as a converter would. These threads may interest you as well: |
GCRicker
Posted: 03 Feb 2020 at 1:38pm |
I went to the RPod dealer this past weekend, and the good news is that I ordered the new 2020 RPod 190! It should come in around the 1st week in May. The bad news is that we talked about the microwave not being able to run on their 1000 watt inverter, and getting a 2000 watt inverter would be very costly. I guess I'm going to have to learn to cook on the stove top.
However, the big concern I have now, and my dealer's service team is investigating, is that the RPod comes with a WF-8735P converter. I was planning on using a Battleborn 1000 Amp lithium battery, but this converter is not lithium compatible, and will not fully charge lithium batteries. Has anyone upgraded their RPod to lithium and were you able to find a direct replacement for the WF-8735P converter that would work? |
Posted: 31 Jan 2020 at 12:50pm |
Just to put some numbers to it, my microwave draws 1414 watts so it would require something like 150A at 12V assuming 20% inverter and wiring losses, which would be pretty typical. If you have a 100 amp hour lead acid battery you would consume about half of your usable 50 amp hour capacity in just 10 minutes of microwave runtime. If you really want to run the micro from your battery I suggest sticking to nuking popcorn and warming leftovers and installing a dual battery system.
Pod_Geek
Posted: 31 Jan 2020 at 11:21am |
Please let us know what options your dealer might offer. I fear that running a microwave off a relatively small inverter may be, err, tricky. As mentioned it will drain your battery very quickly. We have always used a generator when off shore power to run the microwave..
GCRicker
Posted: 31 Jan 2020 at 11:03am |
Thank you all for your replies. It appears that I will have to use a 2000-watt inverter if I want to use the Microwave. That means heavier gauge wire between the batteries and the inverter too. I'll talk to my dealer about this and see what he says.
Thanks again all. |
Olddawgsrule
Senior Member Joined: 20 Sep 2017 Location: New Hampshire Online Status: Offline Posts: 1014 |
Posted: 30 Jan 2020 at 4:41pm |
Factory installed and not to a designated outlet seems far to small for most uses. I have a Self-installed 1000 watt inverter and plug directly into that. Currently only to charge my laptop and the occasional wife's use of hairdryer. The question is: What do you want it to do? Then can it.. Personally, I'd want an inverter I can shut off when not using. Then again, last run (8K plus miles) it wasn't used at all (and I mainly boondock) and wondering if I will remove it... Can you turn it off?? That would be a major point for me. Then what is it costing me compared to a quality unit I can buy and wire in. |
