  New Posts New Posts RSS Feed: No outlets are working
Topic ClosedNo outlets are working
Direct Link To This Post Topic: No outlets are working
    Posted: 31 Jan 2020 at 9:32am
Our 179 has one GFCI located under the bed and AFAIK all the other AC outlets connect through it (I don't know about the fridge or the microwave). So if the GFCI won't reset, either the GFCI is faulty, or something downstream is causing a fault.
I would probably pop out the GFCI outlet and disconnect the slave terminal (turn off the breaker before you do this). Then turn the breaker back on and see if the GFCI will reset. That will tell you for sure if the GFCI is broken or if you have something wrong downstream.
Woodmiester View Drop Down
Direct Link To This Post Posted: 04 Feb 2020 at 8:42am
You most likely have a GFCI on any exterior outlets you have.
Swampfox
wthoms2000 View Drop Down
Direct Link To This Post Posted: 13 Feb 2020 at 3:30am
If 12 volt system works and 110 does not, most likely the circuit breakers. Flip them off and then on to reset.
Good luck!
Porta Poddy
Wil and Luz, Orange County, CA
2017.5 179 HRE
2021 Ranger XLT FX4
REDARC Brake Controller
