  New Posts New Posts RSS Feed: 7-pin Connector
Topic Closed7-pin Connector
Dottiedad View Drop Down
Direct Link To This Post Topic: 7-pin Connector
    Posted: 12 Feb 2020 at 5:46pm
Hi folks. I have a 2010 Rpod 175. I unknowingly dragged the connector cable on the ground long enough to strip a few wires. I brilliantly ordered a new 7ft cable and connector. Then I brilliantly assumed that I could splice it into the junction box under my Rpod frame - COLOR for COLOR. Wrong! Now, only the turn signals work. Can someone furnish a diagram of what color wires on the chassis work what function? White, green, red, black/white, black, brown, etc. Then I could reshuffle the colors to match my truck (2000 GMC Sierra). Thanks a bunch.
wthoms2000 View Drop Down
Direct Link To This Post Posted: 13 Feb 2020 at 3:18am
The best and safest way is to use the old plug and test which wire color went to which plug socket on each of the 7 pins. Then check the new plug wires to match the right "old" colors on the trailer to the right corresponding "new" plug sockets.
This is provided the trailer wire colors are still connected to the trailer, and you still have the old connector to examine.
Good luck!
Porta Poddy
Wil and Luz, Orange County, CA
2017.5 179 HRE
2021 Ranger XLT FX4
REDARC Brake Controller
Direct Link To This Post Posted: 13 Feb 2020 at 7:45am
here's some references from etrailer. Use 7 pin RV standard in center.
Olddawgsrule View Drop Down
Direct Link To This Post Posted: 13 Feb 2020 at 7:48am
Looking for this?
Byways no Highways
2017 Tacoma
Truck Camper Build
2004 F150 My Overlander
Direct Link To This Post Posted: 13 Feb 2020 at 1:36pm
When I did wiring work on my trailer, the colors matched the etrailer pictures for a 7 way RV standard. Example - Yellow was the back-up light.
Direct Link To This Post Posted: 14 Feb 2020 at 7:00pm
Thank you very much for helping me out. I'm back up and running.
For anyone with an Rpod similar to my 2010 175, Olddawgsrule's diagram matches my trailer (and truck). After 3 hours of crawling underneath, swapping wires, pulling my taillights, metering every possibility, it turns out that the replacement cable I bought from Amazon is in fact correct - color for color.
Scraping my cable on the highway shorted out a fuse in my truck giving me all kinds of crazy inconsistencies on the meter. Once the 10amp fuse was replaced, I saw what a nice, perfect swap cable I had purchased. Here is the link for those who ever need to replace a 7-way cable. It's a Proline Power 7-Way Plug.
