Charging battery |
Post Reply | Page <123> |
Author | ||
tony rpod 180
Groupie Joined: 18 Aug 2018 Location: Arkansas Online Status: Offline Posts: 75 |
Topic: Charging battery Posted: 02 Mar 2020 at 8:45am |
Ok thank you all , I WILL NOT be doing that, just a crazy thought.
GMC Canyon/RPoder
Posted: 02 Mar 2020 at 11:27am | |
Please try to avoid 2 stroke engines. A single 2 stroke engine produces as much pollution as 40 - 50 automobile engines. If you've ever gone to countries where 2 stroke motorcycles are common, you'll get a sample of the poison they put into the air.
Posted: 02 Mar 2020 at 2:04pm | |
The TailGator is EPA and CARB certified. There is a big difference between a generator that runs at an almost constant speed and a scooter that has to accelerate and decelerate frequently, more so in city traffic. A badly tuned carburetor in a 4 cycle engine can be quite dirty also.
Posted: 03 Mar 2020 at 4:23am | |
You can solve the gasoline problem by running on propane. There is a little 700 watt continuous rated propane 4 stroke generator for sale on both the zon and the depot websites for $250, anybody have any experience with it? Baja brand but apparently identical except branding to the Ryobi version.
Posted: 03 Mar 2020 at 7:01am | |
Of course, there is not even the remote possibility of running anything of significance with this generator (AC or convection microwave). It would be good for charging the battery/batteries though.
Posted: 03 Mar 2020 at 12:38pm | |
Since you are using a high pressure hose to go from the propane tank to the generator its probably a good idea to either use a filter or an oil free hose as you suggest. As I understand it the pressurization of the hose is what squeezes the oil contaminates out of the hose material. That's not a problem with the generator propane conversion kits like I have on my Honda which use a regulator at the tank. Yeah, any little generator like this would only be good for battery recharging, unless you also install a 2 kw + inverter and use that to run the microwave for short periods. Forget running the a/c, but I find I almost never do that anyway because of the nighttime generator restrictions at most campgrounds. Now that I think about it if not trying to run the a/c off grid it would be lighter, cheaper and more convenient to install an inverter for the microwave and the occcasional ac load and carry the little propane genny. if I was starting over I'd consider doing it that way. The 2-3kw sine wave inverters are down around $300-$350 now and only weigh about 10 lbs.
Olddawgsrule
Posted: 03 Mar 2020 at 3:21pm | |
I'm here reading both of ya's.. Chuckling over your thoughts of yet another generator..
Sorry guys.. Don't have and still see no reason..
Posted: 03 Mar 2020 at 4:37pm | |
Don't see a reason for a generator? To each his own, of course, but does that mean you never stay anywhere without full hookups? TT
FJ Cruiser |
Posted: 04 Mar 2020 at 7:15am | |
What do you do if you're camped for a week under the tree canopy with no hookups? That is typical for me in the Appalachians. Can't use solar under those conditions. Either you run your TV and recharge with the alternator (which is very inefficient) or you bring a genny. I'd love to have a nice silent propane fuel cell but they aren't available yet. Or, you could get one of these and pedal your behind off for 12 hours straight |
Olddawgsrule
Posted: 04 Mar 2020 at 7:23am | |
Very rarely stay with any hookups.
