Battery Maintenance? |
Post Reply | Page 12> |
Author | |||
RoverPod
Senior Member Joined: 07 Mar 2020 Location: Virginia Online Status: Offline Posts: 118 |
Topic: Battery Maintenance? Posted: 22 Apr 2020 at 6:42pm |
Thanks!
Posted: 22 Apr 2020 at 10:40am | ||
We are plugged in 24/7. I check water levels about every 3 months. I don't disconnect or turn off anything. I think I will dewinterize this week, just because it feels good to do so.. 4 trips cancelled so far.. but such is life. But, when I dewinterize, and sanitize tanks and plumbing, I will check the batteries. and top them off as/if needed.
Posted: 21 Apr 2020 at 6:35pm | ||
You don't need to disconnect or shut down anything when you check your water levels. `The battery will be at around 13V whether you disconnect or not. There is no shock hazard at that voltage, you can touch the battery + terminal with one hand and the - with the other hand and not feel a thing. But, as StephenH says, don't ever short out the battery + terminal to either the - or to the trailer frame with anything metallic as that would cause high current to flow and so creates a risk of burns and fires to occur.
podders Helping podders - pHp Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6290 |
Posted: 21 Apr 2020 at 5:07pm | ||
Disconnect from shore power is not needed if you go to your power panel and turn off the converter (on mine, it is the bottom circuit breaker). If you are not using metal when working around the batteries, you don't necessarily need to disconnect the cables unless you need to do so for access to the cell covers. Be sure to use distilled water when adding to your battery. That way, you don't introduce contaminants to the electrolyte.
RoverPod
Posted: 21 Apr 2020 at 4:56pm | ||
Do you need to 1) disconnect the shore power when you check the water levels and 2) disconnect the battery cables when you check?
Posted: 21 Apr 2020 at 8:09am | ||
+1 to mcarter. Check water level at least monthly to start with if leaving the batteries on a charger. There are so many variables (battery size and chemistry details, temperature, charger settings and whether the charger has been powered down resulting in a reset) that its not a one size fits all question, and its not worth exposing the plates due to lack of watering. Once you get an idea how your system performs you can cut back on watering checks if you want to.
Posted: 20 Apr 2020 at 7:20pm | ||
If there is a cut-off switch, the LiFePO4 battery can go for a year or more since the self-discharge rate is so low (~2% / month). The only limitation is not charging it below 32F. This is what the specifications for the ExpertPower battery I purchased say: Charging: 32°F to 140°F Discharging: -4°F to 140°F |
Posted: 20 Apr 2020 at 6:21pm | ||
I have the original battery in my 2015 178. It is in the box, with 120 power applied from outlet to trailer, so converter is maintaining it. I check the water levels each and every month, and add acid/water when required.
Posted: 20 Apr 2020 at 5:49pm | ||
I normally check mine every two months except during the winter here in northern Michigan. In November both batteries (12v. Interstate, deep cycle, group size 24) get pulled out of the 177. They are placed on the concrete floor in our unheated garage. Before charging I check for electrolyte levels and clean the top of the battery with baking soda and rinse off. They are then given a trickle charge of 2 amps from 24-36 hours or until fully charged. They then sit in hibernation until the following May when I repeat the process and then re-install in the 177. Batteries are 9+ years old, we boondock a lot so the batteries are used a lot, they have been very dependable over the years. Am curious to see how long these will last.
TearlessTom
Groupie Joined: 25 Jan 2019 Location: Spanish Fort AL Online Status: Offline Posts: 85 |
Posted: 20 Apr 2020 at 3:23pm | ||
Thanks for the info. That is what I was looking for.
I do let them run down from time to time as I have to borrow the extension cord that it is hooked to shore power with for other yard work duties and often forget to plug it back in until I hear it beeping. Hopefully they will be ok but I fear the worse. I will check Wednesday when I am off.
Tearless Tom
2017 R-Pod 180 2014 Ford F-150 XLT 2WD 5.0 |
