  New Posts New Posts RSS Feed: Protect Your Awning
Topic ClosedProtect Your Awning
lostagain View Drop Down
Direct Link To This Post Topic: Protect Your Awning
    Posted: 28 Apr 2020 at 8:50pm
I'm sure many of you already know this trick but I'm new to awnings since our Pod had the little eyebrow and our Sonoma has one of them fancy schmancy electric awnings.  I was worried that our NV desert sun would turn the awning material into feathers and rags so I fashioned a cover for it.  I got a piece of 4" dia. 10' long corrugated smooth plastic drain pipe form Big Box Hardware and Building Supply for $10.  I cut a strip out of it lengthwise of about 3" and it snaps right over the rolled up awning and completely protects it from the sun.
I'm not so sure I'd travel with it since it might blow off, though I'll be looking into some way to fasten it down securely.  But, even if I only use it at home, it will keep the sun off a great deal of the time.
Fred & Maria Kearney
Sonoma 167RB
Our Pod 172
Direct Link To This Post Posted: 29 Apr 2020 at 8:13am
Sounds kinda like a diy version of this?
The problem with the Amazon one is that it doesn't cover the edge of the awning that's attached to the RV which is where I've usually seen the most damage. Is yours covering that connection point?
Direct Link To This Post Posted: 29 Apr 2020 at 9:01am
It's the same idea, but $10 sure beats $105.  Whether it fits snugly up against the point of attachment of the canvas depends on the particular awning.  Mine fits quite snugly so I'm not worried about the attachment point being damaged.  If that was a problem, it would be an easy fix.  The extra piece that gets cut out could be attached to the upper edge if you needed to fill the gap and have a little overlap.
The tube is cheap enough that even if it doesn't last more than a few years out in the sun, it is sure better than replacing the awning canvas.
Sonoma 167RB
Our Pod 172
GlueGuy View Drop Down
Direct Link To This Post Posted: 29 Apr 2020 at 11:16am
I would go with the $10 solution...
Direct Link To This Post Posted: 29 Apr 2020 at 2:23pm
+1. if those guys are selling very many they're making a killing, looks like a 950% markup.
